Like some others on this forum, I've broken the backlight on my T430 when attempting to fit an IPS panel to it.
I did this before with a T601 I made and was able to fix it by piggy-back soldering a new fuse over the broken one. However this time when I tested the fuse at F3 (the backlight fuse I'm told) with a multimeter I get a reading from it, so the fuse doesn't appear to be broken.
Is there any other possible cause for this problem?
T430 backlight issue (Fuse F3 appears fine?)
Re: T430 backlight issue (Fuse F3 appears fine?)
Bad LCD?
Thanks for your reply. It was a FHD lcd with a converter board. I didn't get any visible output to the screen on the new panel (though I could try again with a torch possibly) I replaced it with the old panel when I could tell something had gone wrong and have been using that to test it. I definitely get an output but no backlight.
Make sure to remove power and battery first, then check all the (LCD) cable connections.
I'm not familiar with this T430 LCD-mod, but I found some info that maybe of use.
https://www.ebay.ie/itm/203206466378 (see the description)
https://www.reddit.com/r/thinkpad/comme ... 0_fhd_mod/
Issue with Intel 6300 WiFi card in my T430
by sktn77a » Sun Feb 11, 2024 3:46 pm » in ThinkPad T430-T490 / T530-T590 Series - 5 Replies
- 889 Views
Last post by ZaZ
Sun Mar 10, 2024 10:16 pm
X230 1440p backlight dead
by apojoga » Wed Nov 01, 2023 4:57 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1755 Views
Thu Nov 02, 2023 1:41 am
- 2079 Views
Last post by DavidGould
Tue Dec 12, 2023 4:17 pm
T430 Thinklight and Integrated Camera not working
by wurmhol3 » Tue Oct 24, 2023 10:58 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 2896 Views
Fri Oct 27, 2023 7:12 am
