t540p new lcd panel not working
T430-T490, T530-T590 Series
Siurczek
#1 Post by Siurczek » Wed Sep 28, 2022 8:14 am
Hello.
I have t540p with broken hd tn lcd panel with is working but its smashed so I decided to upgrade to fhd ips and bought new panel (LP156WF6-SPK6) and it appears it doesn't work it just blinks very lightly cauple times at the start and thats it (and its second fhd panel that I tried that does that).
Am I missing something?
Edit: title
Re: t550p new lcd panel not working
#2 Post by RealBlackStuff » Wed Sep 28, 2022 9:18 am
Can you see anything at all, even just a few things, when you shine a flashlight on the screen?
Did you remove power and batteries before the screenswap?
If not, you may have blown the backlight fuse, located near the LCD-connector on the motherboard.
Solder a new one on top of the old one (3A/32V/fast).
Lenovo: X240, X250, T440p, M900 Tiny (all with W7/SP1)
Siurczek
Re: t540p new lcd panel not working
#3 Post by Siurczek » Wed Sep 28, 2022 12:41 pm
well if I connect old screen everything is fine so I think fuse is ok. I should mention earlier that I see those flashes/blinks when I shine on new panel with flashlight
#4 Post by axur-delmeria » Thu Sep 29, 2022 10:41 pm
Based on the T540p FRU list https://download.lenovo.com/parts/Think ... 131107.pdf, there are 3 LCD cables available:
04X5539 FRU EDP Cable ASM Wedge
04X5540 FRU EDP Cable ASM (Flat / FHD)
04X5541 FRU EDP Cable ASM (Flat / FHD++)
You may need 04X5540.
Backup: X601 Core 2 Duo T8100
Toy: X60F Core Solo U1300
:cry:
Siurczek
#5 Post by Siurczek » Sun Oct 09, 2022 2:45 pm
yes it was the cable. Everything is working now
#6 Post by axur-delmeria » Sun Oct 09, 2022 11:33 pm
Glad it worked. :)
:cry:
