Fwupdmgr update reports the following error. Apparently, this error is caused by an outdated bootx64.efi file on the rescue partition of my T480.
Does anyone know how I can update the rescue partition please or how I can force the update to complete success.
Thanks.
Devices with no available firmware updates:
• TS512GMTE452T
• Thunderbolt host controller
• UEFI Device Firmware
Devices with the latest available firmware version:
• Embedded Controller
• Intel Management Engine
• MZVLB512HAJQ-000L7
• System Firmware
║ Upgrade UEFI dbx from 83 to 217? ║
║ This updates the dbx to the latest release from Microsoft which adds ║
║ insecure versions of grub and shim to the list of forbidden signatures due ║
║ to multiple discovered security updates. ║
║ Before installing the update, fwupd will check for any affected executables ║
║ in the ESP and will refuse to update if it finds any boot binaries signed ║
║ with any of the forbidden signatures. If the installation fails, you will ║
║ need to update shim and grub packages before the update can be deployed. ║
║ Once you have installed this dbx update, any DVD or USB installer images ║
║ signed with the old signatures may not work correctly. You may have to ║
║ temporarily turn off secure boot when using recovery or installation media, ║
║ if new images have not been made available by your distribution. ║
Perform operation? [Y|n]: y
Downloading… [***************************************]
Decompressing… [***************************************]
Authenticating… [***************************************]
Decompressing… [ ]Blocked executable in the ESP, ensure grub and shim are up to date: /run/media/root/SYSTEM/EFI/Boot/bootx64.efi Authenticode checksum [5b89f1aa2435a03d18d9b203d17fb4fba4f8f5076cf1f9b8d6d9b826222235c1] is present in dbx
T480 - Blocked executable in the ESP - bootx64.efi outdated ?
Re: T480 - Blocked executable in the ESP - bootx64.efi outdated ?
Update your system first and update-grub?
[x280] Undervolting permanantly disabled? BIOS downgrade blocked!
by Bookoflife » Thu Mar 07, 2024 1:21 am » in ThinkPad X230-X280 / X390 Series - 1 Replies
- 393 Views
Thu Mar 07, 2024 1:47 am
T480: What kind of battery life can I expect with a WQHD display + 96Wh of battery?
by Maverick000 » Thu Oct 19, 2023 9:12 am » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 4515 Views
Last post by theterminator93
Tue Mar 05, 2024 10:27 pm
- 1 Replies
- 2583 Views
Last post by Badcatalex
Fri Nov 10, 2023 11:21 am
updating T480 bios without Windows (I use Linux)
by redglow » Fri Nov 03, 2023 3:15 am » in ThinkPad T430-T490 / T530-T590 Series - 25 Replies
- 30479 Views
Last post by redglow
Tue Nov 14, 2023 1:00 pm
