I Have a T480 it's a pain to find an original battery for it, because of whitelisting no fake battery available in local market here are working (fake batteries are not charging),
the T480 uses batteries of type 61, but I figured that the t460 which a 68 type has the exact same pinout only it has a misalignment which can't physically connect to the the battery compartment in the T480
So, If I am able to tear-down the 68+ and somehow try to physically align the socket and re-cell it with some good 18650 will it work and get recognized by the EC in the T480?
In theory will the bms board of a 68+ battery work in T480?
Re: In theory will the bms board of a 68+ battery work in T480?
tldr: It works, the 68+ battery worked on my T480
I have just bought a used original 68+ with high cycles 600+ with 33% wear level, I cut the notch in the socket of the 68+ battery and connected in a flimsy way, the battery is a bit smaller than the 61+ and the connector doesn't align with the laptop battery input socket,So I will try recell it and rearrange it in a new case suitable for the T480 and do the vantage calibration.
- 1 Replies
- 7051 Views
Last post by robinadams
Fri Dec 15, 2023 12:05 pm
T480: What kind of battery life can I expect with a WQHD display + 96Wh of battery?
by Maverick000 » Thu Oct 19, 2023 9:12 am » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 3965 Views
Last post by theterminator93
Tue Mar 05, 2024 10:27 pm
Thinkpad T480 with dummy internal battery
by A Monell » Thu Jan 25, 2024 3:02 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 934 Views
Last post by A Monell
Fri Jan 26, 2024 8:06 am
- 11 Replies
- 45918 Views
Last post by Dossing Around
Fri Oct 13, 2023 10:54 am
Users browsing this forum: No registered users and 54 guests
