T470 ups and downs, new project, need advice
Hello, so my sons X201 finally died, he was soo sad for weeks
I decided to buy him a newer thinkpad which can help him for at least 5 years or so, so I looked into T470, went on ebay and found one for 45 dollars, with no hdd/ssd, no ram, bought it, I also sent a DM to the seller asking him if its a functional laptop or is just for parts(so that I would know how to proceed with my project) , the guy said the laptop misses the hdd/ssd because it as a corporate laptop at his workplace, and they also reuse the PSU for other laptops and also kept the ram to upgrade some of the machines that they kept, but otherwise. it was just a fully functional machine provided all the missing components get replaced, which was fine by me.
laptop arrives, and with the exception of 2 nasty sticker marks, the rest of the laptop was impeccable, i cleaned the sticker marks , I installed ram, SSD and pluged in a slim tip charger i already had from my P1 gen 1, and .............nothing happened. well, actually something did happen, the start button flashed green 3 times, but thats it. it wont start.
what am I missing here?
any help will be greatly appreciated.
thanks
thanks
W530, 3840QM, 32GB, K2000M
P1, XEON 2176, 32GB ECC, P2000, IPS
X230, 3320M, 16GB, HD4000, IPS
T601F X9000, 8GB, X3100, UXGA FlexView 1600x1200
T61 14" 4:3, T9500, 8GB, NVS140M
T60 14" 4:3, T7600, 3GB, GMA950
P71, 7700HQ, 16GB, P600, IPS
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
Re: T470 ups and downs, new project, need advice
Remove all RAM, then try to boot.
If there is any life left in it, it should now beep 1-3-3-1.
Does it have a battery?
does it matter? the laptop was plugged in when I tried to boot it up
and yes, I tried both with and without the battery, but i have no idea if the battery is functional or not
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
RealBlackStuff wrote: ↑Thu Mar 09, 2023 3:18 amRemove all RAM, then try to boot.
ok, I just did that, i didnt get a 1 3 3 1, i got a ...... chime, like an 8 bit music, for about 2 or 3 seconds
never heard this sound from any of my thinkpads, and boy do I have a lot of them
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
Yes, it matters. The T440 and later models have some odd quirks involving the internal battery, though TBH I only have limited experience with these newer models (I have yet to own a Thinkpad newer than the X220) so I can't speak with absolute certainty.
ooohh, I see, well, to be fair, its my first thinkpad which had the dual battery configaxur-delmeria wrote: ↑Thu Mar 09, 2023 6:49 amYes, it matters. The T440 and later models have some odd quirks involving the internal battery, though TBH I only have limited experience with these newer models (I have yet to own a Thinkpad newer than the X220) so I can't speak with absolute certainty.
most of my laptops are retro style thinkpads, BUt i also own a P1 , but that one only has internal battery, and no external one, so yeah, my experience with these types is also limited, and its the first time i hear they have specific quirks, thanks for the heads up
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
Seems to be a known problem with T470.
Check this out: https://forums.lenovo.com/t5/ThinkPad-T ... -p/4151449
thanks alot, that explains itRealBlackStuff wrote: ↑Thu Mar 09, 2023 8:29 amSeems to be a known problem with T470.
anyway, i finally managed to make it work, unfortunately it has a faulty keyboard, so will have to change that
however I am a bit puzzled about the connectors on the mobo, does this laptop come with a m.2 sata interface or the m.2 nvme interface?
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
The T470 supports M.2 NVMe SSDs as stated in the PSREF: https://psref.lenovo.com/syspool/Sys/PD ... 0_Spec.PDF
The M2. 2280 NVMe is mounted on a caddy which is installed on the HDD bay. It connects to the system board via a cable.
Its WWAN slot supports M.2 2242 SATA SSDs.
ok, so i made it work, I installed W10 pro on the sata 3 SSD and a linux distro on the M.2 sata 42mm SSD. I have some keys which dont work and the keyboard will get replaced soon, BUT my main question now is about the batteries, so I have a 6 cell external battery and the 3 cell internal one, the problem is the internal one, which supposedly should help me swapping the external one when its out of juice, well, the internal one is the first one to be used by the system, and the external one starts draining only after the first one hits 5%, so how da helll am I supposed to hot swap the external one when that one gets drained if the internal one is already drained? what am I missing, is there a way to set it up so the external battery drains first?
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
Keep the charger in when you swap batteries.
ok, i got the joke, it means there is no way to get around this, but then why the hell did they market this laptop as having a swap-able battery on the go if you need a wall socket to perform this activity?
anyway, I am amazed that no one in the community created a custom bios which to perform the discharging of batteries first external and then internal. what the hell, we can create custom bios for using a W700 cpu inside a T61 ( X9000), but we cant create a bios for batteries usage?
T470 6300U
R61i, T430s
RIP: T43p, X201
T470 6300U
R61i, T430s
RIP: T43p, X201
That's why it stops at 5%. The theory is that a 5% charge is enough to swap batteries.TinkerMan wrote: ↑Fri Mar 17, 2023 5:31 amwell, the internal one is the first one to be used by the system, and the external one starts draining only after the first one hits 5%, so how da helll am I supposed to hot swap the external one when that one gets drained if the internal one is already drained? what am I missing, is there a way to set it up so the external battery drains first?
AFAIR, when I last checked into it - there is no way to force the external to always drain first. The algorithm supposedly drains the battery with less wear first, so the order can change over time.
I believe this functionality is not in BIOS, but in EC. In any case, the answer is that it probably did not bother enough people. The complexity/benefit tradeoff may not be very high, dunno.TinkerMan wrote: ↑Fri Mar 17, 2023 9:51 amanyway, I am amazed that no one in the community created a custom bios which to perform the discharging of batteries first external and then internal. what the hell, we can create custom bios for using a W700 cpu inside a T61 ( X9000), but we cant create a bios for batteries usage?
Any Advance docks for ThinkPad T470?
by ThinkPad560X » Wed Feb 28, 2024 1:12 am » in Off-Topic Stuff - 4 Replies
- 334 Views
Wed Feb 28, 2024 3:21 am
ThinkPad T470 bios locked
by ThinkPad560X » Sat Mar 02, 2024 1:43 am » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 415 Views
Last post by ThinkPad560X
Sat Mar 02, 2024 1:58 pm
ThinkPad T470 motherboard swap
by ThinkPad560X » Tue Mar 19, 2024 12:57 am » in ThinkPad T430-T490 / T530-T590 Series - 10 Replies
- 354 Views
Wed Mar 20, 2024 9:39 pm
Project Butterfly / 701c.org - New Videos
by pkiff » Tue Jan 16, 2024 5:01 pm » in ThinkPad Legacy Hardware - 3 Replies
- 1104 Views
Last post by pkiff
Thu Mar 14, 2024 3:57 pm
