Hi Folks,
I have upgraded by T430 with an AX200 wifi, with this upgrade I also needed to have the Ivyrain BIOS flashed to revome wifi whitelist. I have an EGPU setup (EXP GDC + 1050ti) which was working fine with the stock Lenovo BIOS, but since the Ivyrain update the laptop gets stuck at the Lenovo boot screen when the EGPU is connected and wont progress further. Any ideas what setting should I change in the Ivyrain bios to have the EGPU up and running again?
eGPU EXP GDC does not work after Ivyrain BIOS update T430
IBM Thinkpad T601, Boe-Hydis UXGA, Native Penryn, QX9300, Intel X3100, 8GB Crucial RAM, 250GB Kingston SSD
Re: eGPU EXP GDC does not work after Ivyrain BIOS update T430
Try enabling Secure Boot, that seems to help.
Thinkpads
R51: Pentium M 1.5 GHz Banias, 2GB DDR1, ATI Radeon 7500 32MB, 15" 1024x768, 40GB HDD
R500: C2D P8400, Intel GMA 4500MHD, 15.4" 1280x800
T530: i7 3610QM, 16GB DDR3L, Intel NVS 5400M, 256GB SSD + 700GB HDD, 1600x900, Classic keyboard
SK-8835 Ultranav keyboard Japanese layout
My W530 with OEM BIOS won't work with my EXP GDC. But my X330 with 1vyra1n works with the EXP GDC (partially - I can get acceleration to the internal display with Optimus but HDMI out on the GPU doesn't work with my crappy Emerson flatscreen).
lenovo P71, X330, X60s
T430 does not turn on with RAM
by eladom » Tue May 30, 2023 3:43 pm » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 1470 Views
Last post by RecTech
Wed May 31, 2023 8:59 am
T440p the fan does not work on the new cpu
by EGR24_Brony » Wed Jul 19, 2023 3:09 pm » in ThinkPad T430-T490 / T530-T590 Series - 5 Replies
- 1535 Views
Sat Jul 22, 2023 12:24 am
X230 does not boost after mobo upgrade.
by Garlic Bread » Sat May 27, 2023 12:02 am » in ThinkPad X230-X280 / X390 Series - 3 Replies
- 1132 Views
Last post by Garlic Bread
Sat May 27, 2023 9:52 am
T590 - Backlight keyboard not working and not even showing up in BIOS
by ecco88 » Tue Jun 06, 2023 3:49 pm » in ThinkPad T430-T490 / T530-T590 Series - 7 Replies
- 1829 Views
Last post by ecco88
Fri Jun 09, 2023 9:57 pm
