Is there any way this would work in a T480?
T430-T490, T530-T590 Series
NickSteel
#1 Post by NickSteel » Mon Sep 18, 2023 3:24 pm
Samsung - 970 EVO Plus 500GB Internal SSD PCIe Gen 3 x4 NVMe
TitoLabieno
Re: Is there any way this would work in a T480?
#2 Post by TitoLabieno » Mon Sep 18, 2023 4:58 pm
Of course, the 970 Evo Plus is compatible with the T480. I currently have a 2TB model installed in my T480.
T480 (Intel Core i5-8350U 32GB DDR4)
T430 (Intel Core i7-3632QM @ 2200MHz, 16GB DDR3L)
X100e (AMD Athlon MV40 @ 1600MHz, 4GB DDR2)
R50e (Intel Pentium M 715 @ 1500MHz, 512MB DDR)
T23 (Intel Pentium III M 1133 @ 1133MHz, 512MB DDR)
#3 Post by axur-delmeria » Tue Sep 19, 2023 4:37 am
If your T480 currently has a 2.5" SATA SSD, you'll need the NVMe caddy and the cable for it.
See: https://www.ebay.com/itm/283614982565
Do note that the T480 only has a PCIe 3.0 x2 link for the NVMe slot so the max read speed won't be in the 3,500 MB/sec range.
Old Faithful: X220 4291-C91 i7-2620M
