Issue with Intel 6300 WiFi card in my T430
T430-T490, T530-T590 Series
sktn77a
#1 Post by sktn77a » Sun Feb 11, 2024 3:46 pm
Yes, I know she's an old boat but my T430 meets all my needs.  I updated the stock Intel N-2200 2x2 wifi card to an N-6205 card with no issues.  I eventually updated to an N-6300 3x3 card (all of these cards were Lenovo FRUs).  The Thinkpad has all three antennas for the 6300 and range/speed is good.  However, since moving to the 6300 card, it is extremely slow to come back online after waking from sleep compared to the 2x2 cards.  Anybody know what's going on here?
Keith
(Formerly 600E, T21, T30, T40, T41, 2xT42, 2xT61p, T420, 2x Ideapad K1)
(Currently 4xT430, 2xT460, H520S, M910q, M920q, M70q)
Re: Issue with Intel 6300 WiFi card in my T430
#2 Post by RealBlackStuff » Mon Feb 12, 2024 1:36 am
My T440p with Intel AC-7260 has the same problem.
After it has fallen asleep it can take up to 3 minutes(!) to reconnect to the internet.
So to avoid 'sleeping' I have an online radio station (Classic FM) running all the time, but with the sound muted as and when needed.
My wife's X250 with AC-7265 does not have that reconnect problem.
Both machines run W7.
EDIT:
This is what I had:
Control panel>Device manager>Network adapters>AC-7260>Properties>Power management>UNticked Allow the computer to turn off this device to save power
Control panel>Power options>Change plan settings>Change advanced power settings>Wireless adaptor settings>Power saving mode>Plugged in: Maximum performance
As an experiment, I have made another power settings change:
Control panel>Power options>Change plan settings>Change advanced power settings>PCI Express>Link state...>Plugged in: Off
This, because my AC-7260 is a PCIe card.
Let's see what happens.
sktn77a
#3 Post by sktn77a » Wed Feb 14, 2024 3:01 pm
Thanks RBS. Yes, I think you're right, it may be something to do with the power saving (although why it should only occur with one of the three cards, I don't know). I'll mess around with that and report back.
Keith
sktn77a
#4 Post by sktn77a » Sun Mar 10, 2024 11:20 am
Well, changed some of those settings and it made a small difference but not really significant. Debating now whether to go back to one of the 2.4GHz cards.
Keith
TPFanatic
#5 Post by TPFanatic » Sun Mar 10, 2024 5:58 pm
A card malfunctioning or failing is within the realm of possibility. I've encountered some 5100 and 6205 acting up, replacing them is easy enough.
6205 and 6300 are very close in performance, sometimes I feel like the 6205 is superior as it is a newer generation than the 6300. 6205 replaced the short-lived 6200. 6300 was the last 3 antenna Intel card, it was hardly better than a 2 antenna anyway.
ZaZ
Moderator
Moderator
#6 Post by ZaZ » Sun Mar 10, 2024 10:16 pm
Could try booting to Linux to see if it exhibits the same symptoms.
xiphmont
#7 Post by xiphmont » Wed Apr 17, 2024 2:43 pm
The 6300 family is known to have a nasty firmware bug that Intel hasn't fixed (card was desupported long ago) and there's no fixing it in the software driver either. The 63xx has always been a dog.
Almost any other card, even older ones, are better choices as they'll actually work reliably and not cause random corruption. That third antenna isn't worth it.
SKA
#8 Post by SKA » Fri Apr 19, 2024 12:02 am
Hi !
Great to hear from you, Sir !
Can you recommend Atheros card for old Thinkpads like T61P, T/W500, T/W530, W700, W701 ?
SKA
#9 Post by RealBlackStuff » Fri Apr 19, 2024 12:45 am
Atheros AR9380 a.k.a. AR5BXB112.
Users browsing this forum: Heemag and 8 guests
