Best T420/x220 keyboard for the swap
I switched recently from x220 to x230 (I bought a completely new one, was forgotten in a company's stock!). I'm missing nothing from my x220 but the keyboard. I'm finally considering the keyboard mod, however I need to get a new US keyboard as the one from my x220 is a bit consumed.
I know that the t420/x220 keyboards were produced by several manufacturer, I got my hands once on my friend's T420 keyboard and I like it a lot, way better than my x220 keyboard. I'm not sure how I can a similar one, do you have a suggestion from where to get a new decent T420/x220 keyboard?
Re: Best T420/x220 keyboard for the swap
Remove the keyboard from your friend's computer, it is just a few screws. Once it is off, you will see a sticker with a FRU number. This is the model number of the keyboard. You want to buy a keyboard with the same FRU number.alisan wrote: ↑Sun Nov 12, 2017 3:14 amI switched recently from x220 to x230 (I bought a completely new one, was forgotten in a company's stock!). I'm missing nothing from my x220 but the keyboard. I'm finally considering the keyboard mod, however I need to get a new US keyboard as the one from my x220 is a bit consumed.
In the meantime I've done that, apparently it is 45N2141 from Chicony, I'll make sure to get that keyboard on ebay and not a compatible model.jaspen-meyer wrote: ↑Sun Nov 12, 2017 8:57 amRemove the keyboard from your friend's computer, it is just a few screws. Once it is off, you will see a sticker with a FRU number. This is the model number of the keyboard. You want to buy a keyboard with the same FRU number.
I have received my keyboard yesterday from 2015pcparts ebayer. It is fantastic.
I have used my x230 palmrest. To fit the keyboard, I have made a small hole under the trackpad, so the central tab that comes out from the keyboard enters without having to cut it . Forget to take pictures
It fits perfectly and I'm enjoying it a lot.
These are the FRUs for the CS09 keyboards.
45N2071 / 45N2036 Alps
45N2141 / 45N2106 Chicony
45N2211 / 45N2176 NMB
The Alps is a bit funky feeling and is best identified by its clickiest trackpoint buttons, like a plug-in mouse, however they are prone to developing disparity between the buttons in that one side becomes suddenly mushy while the other stays clicky for awhile. Messing with the other one will make it mushy as well so they at least feel the same.
Chicony has a long travel feel with minimal impulse force to depress the key and mushy trackpont buttons.
NMB requires more impulse force to depress the keys and clicky trackpoint buttons, and is generally considered the most solid and consistent feeling Thinkpad keyboard, like a desktop mechanical keyboard.
I have managed to equip 2 of my laptops with B+ condition NMB keyboards are they are fantastic. My personal favorite however is Chicony.
Keyboard stickers for ThinkPad T400/T410/T420 and T500/T510/T520 Series
by PowerPC » Fri Feb 09, 2024 2:52 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 1 Replies
- 590 Views
Fri Feb 09, 2024 4:14 pm
- 1 Replies
- 588 Views
Last post by TPFanatic
Wed Feb 28, 2024 7:06 pm
Any considerations with this mobo swap?
by canonmasta » Sun Nov 19, 2023 4:36 am » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 5577 Views
Last post by mikemex
Sat Dec 16, 2023 10:30 pm
X1C5 and X1C6 motherboard swap?
by mikemex » Mon Dec 25, 2023 4:19 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 2 Replies
- 2048 Views
Tue Jan 09, 2024 7:32 pm
