[Solved] X230 hot to the touch but temps are normal
So this is weird, I swapped the motherboard in a x230i from an i3 to an i7 (model 2325), it works fine but the keyboard as well as the underside are getting uncomfortably hot, with an ambient temperature of 25c, idle is between 45-50c, and about 80c with 100% load, it doesn't make sense to be that hot to the touch.
fan seems to be working normally, the vents are clean, and I put new thermal paste thinking that it might have been the issue, nothing seems to work.
I should add that I have swapped the keyboard and palmrest from an x220, and flashed the EC, current bios version is 2.67 (updated from a pretty old one, can't remember the exact version but it was from 2012) but it was hot to the touch from the start even before flashing a new bios and EC.
If i set the fan speed to maximum (with TPFanControl) and the system is idle, temperature drops to 35c and keyboard is just lukewarm.
Anyone ever experienced an issue like this? any ideas?
Daily driver : X330 | 3612qe| 16GB | 4TB ssd| classic keyboard mod | 13.3″ 16:10 2560*1600 screen mod | wifi ax3000hmv | 9 cell battery | usb-c charging |
Backup : T430s | 3612qe | 16GB | 2TB ssd| classic keyboard mod | FHD mod | wifi ax3000hmv | ultrabay battery |
Re: x230 hot to the touch but temps are normal
Get the X230 frubom list and check old against new motherboard.
Your i3 probably had a low voltage CPU, which needs a weaker fan than the i7.
That's your problem I guess.
Thanks for replying, I didn't re-use the heatsink from the i3 motherboard, it came with a heatsink that the seller says it's original to the board, I will try to take it apart again and check the FRU though as you suggested.RealBlackStuff wrote: ↑Thu Mar 15, 2018 11:52 amGet the X230 frubom list and check old against new motherboard.
The problem is that the temperature doesn't seem to be that high per se, it's the fact that the keyboard and base are very hot to the touch, even at 35c they are lukewarm, at 50c they are quite uncomfortable, I checked the temperature with every possible program I could find, they all report pretty much the same, I'm completely baffled with this one.
After taking it apart again I noticed that the area around the keyboard connector was getting incredibly hot, turns out that taping those pins in the classic keyboard on the X230 is not optional as with the T430s (or I just got lucky, but I've done 3 T430s so far)
Moral of the story, if you are going to use a classic keyboard on your X230, isolate these 3 pins!
Source: https://imgur.com/a/fsRe6
Re: [Solved] X230 hot to the touch but temps are normal
Well it is optional if you live in Alaska, for then it is a nice keyboard heater .
Ah, that explains it; my modded T430s also has not had the pins taped, and does not get hot. I wonder what the differences are.Dro wrote: ↑Sun Mar 18, 2018 12:13 pmAfter taking it apart again I noticed that the area around the keyboard connector was getting incredibly hot, turns out that taping those pins in the classic keyboard on the X230 is not optional as with the T430s (or I just got lucky, but I've done 3 T430s so far)
Possibly got hot enough to melt the flatflex disconnecting the pins permanently.
Did you disable the backlight in bios? that's what I did on T430s and I think it could be the reason that I didn't have any issues, X230 doesn't have any option to do that.dr_st wrote: ↑Mon Mar 19, 2018 6:48 amAh, that explains it; my modded T430s also has not had the pins taped, and does not get hot. I wonder what the differences are.Dro wrote: ↑Sun Mar 18, 2018 12:13 pmAfter taking it apart again I noticed that the area around the keyboard connector was getting incredibly hot, turns out that taping those pins in the classic keyboard on the X230 is not optional as with the T430s (or I just got lucky, but I've done 3 T430s so far)
Next time that I'll take apart my T430s I'll disassemble the keyboard too and check if there are any burned out contacts.
FS: Thinkpad x1 yoga 2nd gen OLED 16gb/512gb touch $400
by db999md » Tue Dec 26, 2023 9:25 am » in Marketplace - Forum Members only - 3 Replies
- 2015 Views
Last post by db999md
Sat Feb 24, 2024 11:42 pm
SOLVED On ThinkPad SR650 network don't work
by paolo_holzl » Mon Nov 20, 2023 11:43 am » in Windows 10/11/etc. - 0 Replies
- 2566 Views
Last post by paolo_holzl
Is T420 Died? [SOLVED]
by N4b00 » Mon Feb 12, 2024 4:27 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 4 Replies
- 762 Views
Last post by N4b00
Wed Feb 14, 2024 4:00 pm
[SOLVED] - Screen stays on when lid closed on Thinkpad W530
by MajedS » Thu Mar 07, 2024 12:45 pm » in ThinkPad W530/W540/W541/W550 Series - 2 Replies
- 419 Views
Last post by MajedS
Fri Mar 08, 2024 7:49 am
