X230 keeps suspending, cant wake from sleep, ovrhtng
Dear all,
My x230 sometimes cannot wake from suspend.
I also feel it is extremely hot...
Can anybody please link some video re cleaing the inside? Any other ideas about possible cause?
Is there any safety fuse or other mechanism that kicks in to stop the NB from boiling?
Thanks a lot.
I researched overheating in the forum, could not find a similar set of symptoms.
Thanks a lot.
Re: X230 keeps suspending, cant wake from sleep, ovrhtng
It's extremely hot while in suspend? Makes no sense.
Are you sure it actually entered sleep mode and did not lock up overheating while trying to enter it?
Do you have Lenovo Power Manager installed? Which version? Which operating system?
sorry confusing wording.
It is hot when it is on..... then kind of goes to some state, I do not know if hibernation, sleep, or whatever, only the wireless LED indicator is on.
It is not longer hot of course after it has suspended.
I have win 7, and do have power manager.
However the power manager always fights over control with the normal windows power control... I never know which one is actually controlling the power settings, in fact both are.
I have power manager version 6.
To get some more "fresh air" inside, see this: https://imgur.com/a/uTGUZuV
realblackstuff
Well thanks...how does one get that...
Before you do any hardware mods, try uninstalling the Power Manager completely, and see if the symptoms go away.
dr st
will try thanks
will try thanks
dr st
dont want to celebrate too early,,,but the pc seems to run cooler.
why would lenovo's own app screw the functioning of the laptop?
Dunno. I have seen issues with Power Manager 6, Windows 7 and older laptops (like my X32). Others have seen them as well. In my case, reverting to Power Manager 3 made the issues go away.
However, I don't recall such problems with new laptops...
DR_ST
seems your advice worked. Thanks...
Its happens with windows 10 and maybe with windows 7
Problem is wifi card intel 6205
same problem with this card I have X120e
to fix it replace card on another from whitelist or go to properties wifi card find power transmission option and change it from 5 to 1 (lowest) and viola!
solved!
now windows 10 1909 (and olders) works nice, stable and qiuck! (with SSD of course!)
cheers!
solved!
cheers!
W520 CS, FP, WWAN, I7-2920XM, Q2kM 1TB SSD i540s
current W520, W700, X301, X120e, X230*2, MSI GT72 I7-6700Hq GTX980m, MSI GT683 I7-2860QM GTX970M,
before T23, T40, T43p*3, T61p*3, W500
HELP! I Cant access BIOS menu during windows 11 start
by canonmasta » Mon Dec 04, 2023 5:07 pm » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 3394 Views
Last post by Brad
Sat Dec 16, 2023 6:40 am
x230 Wi-Fi card replacement and external antenna
by Teddy98 » Sat Oct 21, 2023 9:39 am » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 3049 Views
Last post by Qing Dao
Sat Dec 16, 2023 9:59 am
X230 1440p backlight dead
by apojoga » Wed Nov 01, 2023 4:57 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1772 Views
Thu Nov 02, 2023 1:41 am
X230 - what SSD will best fit in the WWAN slot?
by br1anstorm » Tue Nov 14, 2023 3:59 pm » in ThinkPad X230-X280 / X390 Series - 15 Replies
- 5811 Views
Last post by br1anstorm
Wed Nov 15, 2023 6:17 pm
