hi everybody,
sorry for my french english
i bought last week a X240 in use
i add an internal battery, and All was good....even
since this morning
my external battery is near 5% of charge(Battery 2) and not charges
internal battery is charged near 75% (battery1)
two problem
1/when i cut AC alimentation...X240 shut down even batterie 2 is charged
2/ x240 don t shift on internal battery!!!
please do you have any ideas to solve my problems!!!
thinks a lot
Eric
Battery problem
Re: Battery problem
Welcome to the Forum.
Switch the laptop off, close it and turn it over.
On the bottom, left of the battery-bay, is a tiny hole for the Reset button.
Gently use a paperclip or similar to reset your laptop (needs very little pressure to push that button).
It should now start again.
Check in Power manager if one of those batteries might be bad.
T42 Charges and works with the battery in but without battery will not power on.
by kale87 » Fri Oct 27, 2023 3:39 pm » in ThinkPad T40/T41/T42/T43 Series - 0 Replies
- 3172 Views
Last post by kale87
ThinkPad A22m battery recondioning after battery rebuild
by kfzhu1229 » Mon Dec 11, 2023 5:57 pm » in ThinkPad R, A, G and Z Series - 0 Replies
- 2477 Views
- 4 Replies
- 3993 Views
Tue Dec 19, 2023 12:59 am
Strange T480 Shift lock problem.
by unified11 » Mon Feb 05, 2024 7:17 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 444 Views
Last post by ZaZ
Mon Feb 05, 2024 10:52 pm
