Hi.. does anyone knows what specific part of the board is be shorted..
https://imagizer.imageshack.com/v2/xq90/924/LBNJPt.jpg
Admin warning:
picture WAY too big, tags removed. Please read the Forum Rules, especially Section 5: viewtopic.php?f=16&t=14339
Please note: do not repeat-post such pictures, the above link is is enough.
x240 no power (shorted board)
Re: x240 no power (shorted board)
Hey, only way you will know for sure is take one yellow capacitor (small ceramic SMD capacitors and tantalum cap tend to fail shorted) at a time and check resistance like you have done before till shorted part is found.
Cheers, thinkpadcollection
Saw this thread so I thought that I will share my experience with replacing keyboard in my x240 because I had problems with turning the machine back again. After the keyboard was replaced, I periodically tried to turn on the laptop to see whether it works or not. While I did not assemble it back completely (by that I mean putting the X240 into the covers) the laptop was working (turned on). When I plugged everything (wifi card, internal battery, etc.) and put machine into the case, then it wouldn't start upon pressing the power button. I was becoming desperate as to why the machine would work without covers and won't without them. After few tries I tried to start it without internal battery and it worked! But it must have been probably something else because when I let it run for a while, letting it charge the external battery from 0% to 100%, then I tried to disassemble one more time and plug in the internal battery as well. The machine started and charged the internal battery also from 0% to 100%. You have probably another problem but I thought that you might try to run it without battery like I did and maybe it will help.
Off-topic: I still have one problem with my X240 though, after successful replacement of keyboard the function (FN) key stopped working. It's so annoying to adjust brightness, volume and everything using Windows.
X230, X1C7 and B156HW01 V.4 (from a W530 ThinkPad) used as an external monitor using LCD controller board.
Its hard without schematic and also do you had the tools (microscope, heat gun, multimeleter, n etc), if you had them both , watch loise rossman vid on youtube how hes troubleshoot
- 1868 Views
Last post by DavidGould
Tue Dec 12, 2023 4:17 pm
ThinkPad T530 Very little power, Will not power on
by ThinkPad560X » Sun Mar 10, 2024 12:42 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 213 Views
Last post by ThinkPad560X
Sun Mar 10, 2024 12:57 pm
Possibly missing SMD resistor on X210 board
by yitzhaq » Wed Nov 08, 2023 6:28 pm » in 51nb and other modded Thinkpads - 16 Replies
- 5796 Views
Last post by 755cdxd
Wed Jan 10, 2024 6:39 am
- 0 Replies
- 1775 Views
Last post by dvmopar
Tue Nov 14, 2023 8:34 pm
Users browsing this forum: No registered users and 75 guests
