X230 card reader stopped working
Hello
I have a problem with my X230 - a few weeks ago I noticed the card reader stopped working. It's not visible in Windows Device Manager at all. It's not disabled in the BIOS. Also tried booting Manjaro and Ubuntu live cd's and it's not detected there either. I know it used to work, because I copied lots of photos from several SD cards months ago...
I think it happened after I removed the WWAN card and installed an mSata SSD. Could I disconnect something by mistake?
Thanks for any tips!
Re: X230 card reader stopped working
Unless you hit something in the system board with a screwdriver, no. The card reader is not in a separate circuit board, so there's no cable that could get detached.
Welcome to the forum.
The card reader usually powers down and is invisible when not in use. I assume you tried to insert a card, and it did not get detected?
I've run across similar behavior before on my X220. See if the information in the following post is any help.
/viewtopic.php?p=722786#p722786
See also (especially last post in thread):
viewtopic.php?f=43&t=115706
EDIT: On re-reading this thread, I am not sure you are having the same issue I've had, but it still may be worth checking out.
DKB
Thanks for the links, they're pretty informative, however I'm still unsuccessful.
I did dual boot between Windows and Ubuntu and I noticed a "base system driver" appeared in Device Manager (it wasn't there before I dual booted, but the reader didn't work anyway). Unfortunately, the tips provided in those threads did not help. When I changed the .inf file accordingly, now it appears as "Ricoh PCIe SD/MMC Host Controller" in Device Manager but says
I'm using Windows 7 x64.
Lenovo System Update and "Automatic Driver Update" on Lenovo's website don't show the card reader (nor the fingerprint reader, which I reenabled in BIOS).
Any additional tips welcome
EDIT - I found the exact driver mentioned in another thread: " Ricoh PCIe SDXC/MMC Host Controller, by Ricoh Company, version 6.10.10.32, dated 25/05/2011.", ran setup.exe and it installed properly, but is now nowhere to be seen in Device Manager...
Windows cannot verify the digital signature for the drivers required for this device.
A recent hardware or software change might have installed a file that is signed incorrectly
or damaged, or that might be malicious software from an unknown source. (Code 52)
Read my first reply above. Did you actually try to plug in a card?
Yes, however it is slightly possible the only card I have at the moment could be dead. I'll try and find a different one and get back to you...
X230 trackpoint, mouse buttons and some keys still not working after keyboard change
by frog4 » Mon Jan 22, 2024 4:24 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1239 Views
Last post by frog4
Tue Jan 23, 2024 5:22 am
Mike mute LED button / Hotkeys integration of X220/X230 not working with Windows 11
by kokkolis » Wed Feb 28, 2024 12:03 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 2 Replies
- 368 Views
Last post by kokkolis
Wed Feb 28, 2024 3:04 pm
x230 Wi-Fi card replacement and external antenna
by Teddy98 » Sat Oct 21, 2023 9:39 am » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 2577 Views
Last post by Qing Dao
Sat Dec 16, 2023 9:59 am
functional differences between x230 and x230t
by astral » Sat Sep 30, 2023 7:32 pm » in ThinkPad X230-X280 / X390 Series - 4 Replies
- 2955 Views
Sun Oct 01, 2023 4:21 pm
Users browsing this forum: No registered users and 95 guests
