SSD for X250 Type 20CL
I really like this light and responsive machine. Thinking of going the SSD route but it's something I am woefully ignorant of. I see two type of SSDs; One type resembles a hard drive in size and utilizes the existing SATA connectors. The other type resembles an IC on a board with edge connectors. I don't know which one is preferable and I don't know if my X250 is even prepared for the flat card edge connector type of SSD. Any advice and/or guidance would be greatly appreciated.
T440p Win 10 Pro 8 gig memory 500 GB ssd
T520 W7 Pro 8 GB memory
A31/p XP Pro 1 GB memory
A30/p XP Pro 1 GB memory
TP600 Win 2K 288 mb memory
701C Win 98 Don't ask
Re: SSD for X250 Type 20CL
X250 can take 2.5" SSD (up to 9.5mm high) in its main bay.
Recommended: Samsung 860 EVO, any size GB.
It can also take M.2 SSD via its M.2 card slot.
Some people put the OS on it and then use the 2.5" for storage.
You decide what you need.
We have X250 (Model No. 20CM-002SHH), and have:
1) After-market 2.5" SATA SSD (9.5mm as RBS said).
2) We also have a half-sized "2242" (ie: 22x42mm) PCIe SSD 16GB, used as our permanent Paging File (Swap File).
ie: The X250 by itself cannot accommodate any "full-sized "2280" (ie: 22x80mm) PCIe SSD.
Perhaps using adapters might work, but we have no experience in this.
Thank you all for the informative replies. Much appreciated.
380ED display panel replacement - Type 1 and Type 2 panels?
by KylesDigitalLab » Thu Oct 26, 2023 11:26 pm » in ThinkPad Legacy Hardware - 0 Replies
- 2360 Views
Last post by KylesDigitalLab
- 0 Replies
- 207 Views
Last post by Swonco
Thu Mar 21, 2024 12:03 pm
Bios messages being displayed at startup - "Machine Type is invalid" etc.
by axiomcs78 » Thu Jan 11, 2024 10:27 am » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 4 Replies
- 1438 Views
Fri Jan 12, 2024 3:10 am
FS: Thinkpad X31 Type 2672-C2U for parts with dock
by twiceferrel » Fri Jan 12, 2024 3:32 am » in Marketplace - Forum Members only - 2 Replies
- 1330 Views
Last post by RedPanda
Wed Jan 24, 2024 12:19 pm
