Mini PCI-e Wifi Card for X230
Hello Forum Friends,
I'm curious what the fastest mini pci-e wifi/bluetooth combo card is I can use on my x230. Any and all help greatly appreciated.
Thanks in Advance,
-myxomop
Thanks in Advance,
-myxomop
ThinkPad X230 w/ IPS Display (LEN40E2)
Intel Core i7 3520M @ 2.90GHz Ivy Bridge
8GB Single-Channel DDR3 @ 798MHz (11-11-11-28)
180GB Intel SSD Pro 1500
Win7Ultimate x64 SP1
Re: Mini PCI-e Wifi Card for X230
After applying IVyprep/1vyrain it would be:
- the MPCIe format AC-7260, which needs pin 51 taped for BT 4.0
- OR spend a bit more and get an adapter and the newer AX200 with wifi-6 and BT 5.1
I believe Intel 6300 is the best card in that generation. With a modified BIOS (to remove the whitelist that prevent users from installing unauthorized cards) I believe you can upgrade to a 7260. There is also a modified AX200 selling in China, but it's not how intel released it. Depending on the seller, it may or may not have all antenna wires attached. If I were you I'd just stick to the 7260.
Also, keep in mind that there are no Windows 7 drivers for some of the newer cards. Worth checking in case you're still using it.
X1C5: 7600U | 16GB | 1TB | FHD
X1C9: 1145G7 | 16GB | 1TB | WUXGA | WWAN
P14s G1 AMD: 4750U | 32GB | 1TB | PG FHD Touch
T14 G2: 1145G7 | 32GB | 1TB | FHD
If going with 1vyrain you can also get the AX200 ready to go without an adapter https://www.aliexpress.com/item/4001035855462.html
This seller is confirmed everything hooked up correctly, I opened the tin can to check, see here: viewtopic.php?f=69&t=130562&p=858484#p858484
This is now available on ebay as well https://www.ebay.co.uk/itm/392873515376
Do the X230 wifi-antenna cables fit onto that AX3000 card without any adapter?
I've seen some cards selling on Aliexpress that appear to have the old and bigger connector. I think it's called IPEX.RealBlackStuff wrote: ↑Mon Oct 11, 2021 1:05 amDo the X230 wifi-antenna cables fit onto that AX3000 card without any adapter?
Makes sense; laptops with Mini PCIe slots have the old style connectors.
Yes they fit directly, I have it installed in two x230 machines here, both working perfectly. You need the BIOS whitelist removed but otherwise they are plug and play.
Yeah the x230 needs larger connectors, which are provided on the mini PCI-E card I linked. NGFF M.2 versions have smaller connectors that don't match the x230, I believe.
x230 Wi-Fi card replacement and external antenna
by Teddy98 » Sat Oct 21, 2023 9:39 am » in ThinkPad X230-X280 / X390 Series - 5 Replies
- 3009 Views
Last post by Qing Dao
Sat Dec 16, 2023 9:59 am
Wifi Card upgrade suggestions?
by babysheegoth » Thu Jan 11, 2024 1:32 pm » in ThinkPad T60/T61 Series - 11 Replies
- 4878 Views
Sun Feb 11, 2024 11:47 pm
Issue with Intel 6300 WiFi card in my T430
by sktn77a » Sun Feb 11, 2024 3:46 pm » in ThinkPad T430-T490 / T530-T590 Series - 5 Replies
- 881 Views
Last post by ZaZ
Sun Mar 10, 2024 10:16 pm
X230 1440p backlight dead
by apojoga » Wed Nov 01, 2023 4:57 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1745 Views
Thu Nov 02, 2023 1:41 am
