USB NOT WORKING - ThinkPad X260 [FIX]
Hi everybody, I recently bought a x260 but the USB ports are not working (2 of 3 aren't working)
I see what's going on, it's just a small SMD components that blew up. However I don't have the reference because he is burned down..
If somebody can help me.
Pour les francais, comme dit en haut en anglais, j'ai un thinkpad x260 avec 2 ports sur 3 qui ne fonctionnent plus. J'ai un boitier CMS qui a complétement brulé, le southbridge n'est pas touché et mon
interfaçage USB fonctionne encore. Cependant je n'est pas la référence du boitier pour pouvoir le changer...
Greetings,
Cordialement.
Quentin HEC
Greetings,
Cordialement.
Quentin HEC
Re: USB NOT WORKING - ThinkPad X260
U13 on X260 is this: G517F1P81U, a.k.a. TPS2069DGN
(same as U53 on X250 mobo)
Thanks a lot !!!!!RealBlackStuff wrote: ↑Thu Oct 28, 2021 12:44 pmU13 on X260 is this: G517F1P81U, a.k.a. TPS2069DGN
I will update if I achieve succesfully the repair !
- *Senior* Admin
and while you are updating, please update your location to show your city, not just north france..kanteiniii wrote: ↑Thu Oct 28, 2021 1:43 pmThanks a lot !!!!!RealBlackStuff wrote: ↑Thu Oct 28, 2021 12:44 pmU13 on X260 is this: G517F1P81U, a.k.a. TPS2069DGN
thanks
Bill Morrow, kept by parrots & cockatoos
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
~~~Mark Twain~~~
Ok but why you need the city ? That's a bit private ..BillMorrow wrote: ↑Thu Oct 28, 2021 2:16 pmand while you are updating, please update your location to show your city, not just north france..kanteiniii wrote: ↑Thu Oct 28, 2021 1:43 pm
Thanks a lot !!!!!
thanks
Well, that's it ! I finally fix my thinkpad x260 by using not a TPS2069 Power Switch but an AP2815 from an another lenovo product.
After some research on these two components, they are the same but not same manufacturer.
Only one problem. While removing the old power switch that has burn on the mobo, the EN pin just dissapear . It's working perfectly fine even if it's no more here.
I put all picture on google so here is the link :
https://drive.google.com/drive/folders/ ... sp=sharing
Re: USB NOT WORKING - ThinkPad X260 [FIX]
Good to hear that nothing else had burned as well!
@billmorrow: many forum members in USA only indicate either City & State, or just their State (and most also without the country), about which you never complain.
AFAIK the north of France consists of these 3 regions/departments: Nord (where you are), Normandy and Picardy.
It is enough to indicate your region/country as your location.
The village where I live is so small (~640 people), it's not even on most maps, so I just indicate the County (Wexford) as my location.
And here's the kicker: there is only ONE (souvenir) shop, but we have TWO pubs!
Thanks!RealBlackStuff wrote: ↑Sun Oct 31, 2021 3:44 amGood to hear that nothing else had burned as well!
Currently, the north of france is in french "Les Hauts de France" the high top of france in english. We have these dept Oise Pas de calais Nord Picardie
But geographically you're good !
[TR] WTB: New X260 internal & external battery
by Nickolai » Sat Oct 28, 2023 7:37 pm » in Marketplace - Forum Members only - 0 Replies
- 1682 Views
Last post by Nickolai
X260 something loose inside making a clunk when it's turned over
by Tired » Fri Feb 23, 2024 11:55 am » in ThinkPad X230-X280 / X390 Series - 4 Replies
- 544 Views
Last post by mikemex
Sat Mar 02, 2024 2:19 am
Which basic dock for X260?
by devinfriday » Wed Feb 28, 2024 12:05 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 375 Views
Last post by devinfriday
Sat Mar 02, 2024 7:32 pm
- 2 Replies
- 2286 Views
Last post by KALAM1TY
Wed Jan 17, 2024 9:50 am
