I noticed that I didn't need to insulate the backlight pins on my keyboard, and the "keyboard illumination" control vanishes from BIOS when the classic keyboard is plugged in (on my X230). Is this a new BIOS feature? Is isolating pins still required?
Keyboard works fine btw
X230 keyboard swap - autodetecting classic keyboard in new BIOS?
Re: X230 keyboard swap - autodetecting classic keyboard in new BIOS?
I didn't insulate the pins on mine (W530) and upon connection, the ribbon cable got fried and took the Trackpoint buttons with it. I have installed 1vyrain and EC controller patch, for using older batteries, keyboards and having the advanced BIOS menu / white-list removal.
What BIOS version are you talking about? Is it stock / unmodified from Lenovo?
X1C5: 7600U | 16GB | 1TB | FHD
X1C9: 1145G7 | 16GB | 1TB | WUXGA | WWAN
P14s G1 AMD: 4750U | 32GB | 1TB | PG FHD Touch
T14 G2: 1145G7 | 32GB | 1TB | FHD
1vyrain as well. I've also fried keyboards in the past on X230 (near the ribbon cable) and some keys wouldn't work. but this is a new motherboard. perhaps it's a motherboard dependent feature.mikemex wrote: ↑Sun Nov 07, 2021 12:25 amI didn't insulate the pins on mine (W530) and upon connection, the ribbon cable got fried and took the Trackpoint buttons with it. I have installed 1vyrain and EC controller patch, for using older batteries, keyboards and having the advanced BIOS menu / white-list removal.
it also cycles thinklight-off instead of thinklight-backlight-off with the classic keyboard plugged in.
I understood that there are different possible outcomes when not insulating pins. Either the traces on the keyboard will "self-fuse" and everything will be fine, or something will burn and the keyboard will stop working (fully or partially).
What I don't understand, though, is whether the outcome depends on the laptop, keyboard or just some random luck when plugging in the first time.
Classic ThinkPads installed in IBM System/390 and zSeries mainframes
by ThinkDan » Mon Nov 27, 2023 4:39 pm » in ThinkPad Legacy Hardware - 13 Replies
- 4472 Views
Last post by ThinkDan
Fri Feb 02, 2024 4:18 am
T580 Compared to Classic Thinkpads and Macbook Pro
by MisterB » Fri Mar 15, 2024 12:51 pm » in ThinkPad T430-T490 / T530-T590 Series - 0 Replies
- 244 Views
Last post by MisterB
Issues with new backlit keyboard for Thinkpad X230
by dowe » Wed Mar 13, 2024 2:30 pm » in ThinkPad X230-X280 / X390 Series - 3 Replies
- 382 Views
Last post by dowe
Thu Mar 14, 2024 8:25 am
- 1 Replies
- 1814 Views
Last post by TPFanatic
Tue Nov 21, 2023 9:31 am
