Hi folks,
I have two x230 (one for work and one at home), and I recently decided to upgrade the one at home in order to do some music. I've added 16gb ram and a 1TB mSATA drive, everything was working great, but then I decide to do some cleaning of the keyboard.
I turned the computer off, but left the battery connected, and started cleaning. At some point, it powered-on and the mouse was just moving by itself. I tried to press the power button without success and had to remove the battery to power it off.
But now the power button doesn't seem to work anymore. I've switched the keyboard with the one from work and it's working properly, so it seems that I screwed the keyboard somehow with the alcohol I was using to clean it.
Do you think there is something I can do in order to repair it or I should get a new keyboard instead? Also, where would you recommend me to get the keyboard? (I'm in France and not sure where to order?)
Thanks for your help!
Keyboard not working after cleaning, is it fixable?
Re: Keyboard not working after cleaning, is it fixable?
I am sure you can find plenty of parts on leboncoin for the X230 unless you don't want an azerty/French keyboard...
https://www.leboncoin.fr/informatique/2093224040.htm keyboard for10 euro's
another one...https://www.leboncoin.fr/informatique/2017901302.htm
Or look on ebay France or ebay. Germany
Yoga 910, i5 7200u 512GB/8GB, Win 10 Pro
Yoga 930, i7 8550U 512GB/16GB, Win 11 pro
X250 i5 5300U 240GB/8GB, FHD display, 2nd drive 500GB, Win 10 Pro
Yoga 460 i5 6200U 480GB/8GB, FHD touch, Win 10 Pro (project)
X230 trackpoint, mouse buttons and some keys still not working after keyboard change
by frog4 » Mon Jan 22, 2024 4:24 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1241 Views
Last post by frog4
Tue Jan 23, 2024 5:22 am
WTB: Known, working keyboard for 760XL
by pb3623 » Fri Oct 27, 2023 1:56 pm » in Marketplace - Forum Members only - 3 Replies
- 1713 Views
Last post by pb3623
Sat Jan 20, 2024 10:27 pm
- 1 Replies
- 381 Views
Last post by TPFanatic
Wed Feb 28, 2024 7:06 pm
T430 Thinklight and Integrated Camera not working
by wurmhol3 » Tue Oct 24, 2023 10:58 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 2537 Views
Fri Oct 27, 2023 7:12 am
Users browsing this forum: TOTAL and 60 guests
