X230 board not booting after repasting
X230-X280, X390 Series
somuchpain
#1 Post by somuchpain » Wed Apr 13, 2022 1:18 pm
Hello. I tried repasting my X230's CPU but now it won't boot. The only signs of life are when connecting to the LCD assembly where the power LEDs turn on when connecting a charger. Am I completely screwed? What can I try? Thank you in advance :)
OneByteCPU
Location: Bracebridge, Canada in the deep woods of central Ontario
Re: X230 board not booting after repasting
#2 Post by OneByteCPU » Wed Apr 13, 2022 9:26 pm
It sounds like you tried to re-connect the LCD while under power. Is this the case?
Bill
____________________________________________________________
T61 - X201 - Edge 15 - T520 - X131e - X230 - T440 - X250 - T450 - T480
somuchpain
#3 Post by somuchpain » Thu Apr 14, 2022 6:12 am
No, I didn't. Maybe it wasn't clear in the post; I tried plugging and unplugging the charger or battery and that caused the correct LED "animation" in the back of the LCD unit.
somuchpain
#4 Post by somuchpain » Thu Apr 14, 2022 10:07 am
Update: I just turned on the board somehow.. standalone connected to an external display. I haven't been able to reproduce it again I suspect there's some screw or something in the motherboard that is causing weird behavior. What can I do?
