extremely slow X270 on battery
X230-X280, X390 Series
Darekyl
#1 Post by Darekyl » Fri Sep 30, 2022 9:54 am
Hello, i have a X270 and i bough an aftermarket 9- cell battery for it. The problem is, that as soon as the computer recognizes it, it throttles down to exactly 0,39GHz. I checked in Lenovo Vantage and the battery doesn't have a firmware number. Is there a way to get around it, is the thinkpad just picky or should i just return the battery?
ThinkPad x270
Re: extremely slow X270 on battery
#2 Post by RealBlackStuff » Fri Sep 30, 2022 12:02 pm
Is that under any OS?
(Or just under W10/W11...)
Lenovo: X240, X250, T440p, M900 Tiny (all with W7/SP1)
#3 Post by dr_st » Fri Sep 30, 2022 12:06 pm
Welcome to the dreaded X270 battery throttle bug. :(
https://www.google.com/search?q=x270+battery+throttle
Darekyl
#4 Post by Darekyl » Fri Sep 30, 2022 12:30 pm
It seems that even engineers at lenovo make mistakes (or are just a bunch of assholes). It's impressive how i completely missed this.
ThinkPad x270
Darekyl
#5 Post by Darekyl » Fri Sep 30, 2022 12:35 pm
Does anyone have a fix?
ThinkPad x270
#6 Post by RealBlackStuff » Sat Oct 01, 2022 12:31 am
I haven't read everything about that bug, but if it indeed stops if you move the battery-lock-slider, you could try and go a step further by completely removing that slider.
For that you probably need to take the whole laptop apart, but if it is no longer under warranty, so what?
You can then hold the battery in place with electricians tape or similar.
