X240 iGPU not touching heatsink
Hi everyone,
I've run into some crashes lately and only when gaming, so I've narrowed down the problem to the iGPU. I believe there used to be a thermal pad which connected it to the heatsink, but unfortunately it's gone now. Several months ago I put a giant blob of thermal paste to do the job but now that I'm using my X240 as a daily driver I'd like to replace it with a copper plate.
How thick should it be? Do I just use trial and error?
Where can I get copper from (I'd prefer if I didn't have to order online), and how can I cut it?
Re: X240 iGPU not touching heatsink
The integrated graphics is part of the CPU die (the big glass-like silicon rectangle that is covered by the heatsink, as seen on the photo below.
The small silicon die beside it is the PCH (platform control hub) which handles peripherals like the USB and SATA ports. AFAIK that shouldn't make contact with the heatsink's copper plate.
You probably need to clean the fan and cooling fins on the heatsink. Putting too much paste is actually a bad idea.
Backup: X601 Core 2 Duo T8100
Toy: X60F Core Solo U1300
Thank you! I have learnt something new.
The fan appears to be clean. I feel like the silicon is showing its age. My other X240 was fine before, but is also crashing under load. Both idle around 55 and reach 75-85 when web browsing, which is quite toasty (I'm using TPFC and undervolting).
Just out of interest though, how much worse is the airflow when docked?
I happen to require 4 USB ports, but can do without if it improves performance.
An X240 with i5 CPU, a clean working fan and properly applied thermal paste should idle in the low 40s C.
Even when online gaming it should not go over the mid 70s C.
If it has an i7 CPU, add maybe 5 C to those temps.
And this is without fan- or throttle- or undervolt-programs.
Lenovo: X240, X250, T440p, M900 Tiny (all with W7/SP1 and NO updates since 2018).
X300 fan died, possible to replace fan only, not heatsink?
by Insomniac1971 » Thu Aug 18, 2022 8:21 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 7 Replies
- 2398 Views
Last post by piledriver
Mon Dec 26, 2022 6:14 pm
[FS][EU-Germany/Czechia] X240 with X250 touchpad, i5, IPS, 80Eur
by WarhawkCZ » Tue Oct 25, 2022 3:12 pm » in Marketplace - Forum Members only - 2 Replies
- 886 Views
Last post by booysen
Sat Jan 28, 2023 3:36 am
T41 with no heatsink over GPU ok for gaming?
by Jefferson » Thu Aug 25, 2022 9:15 pm » in ThinkPad T40/T41/T42/T43 Series - 3 Replies
- 1641 Views
Last post by WEissbr0t
Wed Aug 31, 2022 7:33 am
What's the best heatsink for an M.2 SATA SSD?
by cultOfThinkpad » Fri Sep 02, 2022 8:04 am » in ThinkPad T430-T490 / T530-T590 Series - 2 Replies
- 1545 Views
Last post by W500tragic
Thu Oct 20, 2022 6:17 pm
