X230 Bluetooth?
X230 Bluetooth?
Hi new to the forum , wondering if my x230 would have Bluetooth or be able to install Bluetooth inside it or would I need to go with a dongle ? Don't have much info regarding the laptop I bought it used it works perfectly just had a Bluetooth device I wanted to connect and wondered if it had it , no idea what age the laptop is , running windows 10 but it has a sticker for windows 7 so guessing it came with that , in device manager don't see any mention of Bluetooth just an error was BCM20702A0 ! Saying there is no driver available? Please help advise much appreciated
Re: X230 Bluetooth?
If I remember correctly, Bluetooth was an optional feature for X230s. Therefore, the first thing you have to check is if you actually have it or not.
In previous versions of Windows the wireless connections were managed via the FN+F5 shortcut. But I don't think it works in Windows 10 unless you have the legacy hotkey software installed. That's not much of an issue, because Windows 10 handles Bluetooth directly. Just go to the BIOS (press the vantage button while booting up and select setup) and go to security, port access, and check that Bluetooth is enabled (I suggest you to leave everything enabled; turning things off saves a little of battery, but have to be re-enabled each time you want to use it). Once enabled, you should be able to turn it on in the Windows management console. If Bluetooth isn't listed, you probably don't have the module installed. To confirm it, check the LEDs below the screen. They have symbols, if you have Bluetooth from factory, there should be a Bluetooth symbol among them, even if it's not lit up.
If you don't have the module, there are two options to add it:
* Via the original and internal module that was offered back then.
* Via a newer WIFI card that doubles as a Bluetooth device.
Since both requiere opening the laptop up, is up to you to decide which way to go. The easiest is the internal, factory module. If I remember correctly, you'll have to purchase the right part, take the palmrest off and add the module.
The second option implies altering the BIOS, in order to remove the "whitelist", which is a "protection" Lenovo installed on such machines to prevent end users from installing "unauthorized cards". Once you replace the BIOS with a whitelisted one, you can remove the original WIFI module and add a newer module. So you can no only install Bluetooth that way; it'll be a newer version that it was impossible back then. On top of that, you'll be upgrading the WIFI card itself, of course.
The older module isn't probably as power efficient as the new one. But Bluetooth consumes so little anyway, that it's probably not much of a concern.
* Original Bluetooth module: 60Y3303 / 60Y3305. It supports Bluetooth 4.0.
* You can pick any WIFI card as long as it is Mini PCIe. The maximum "native" WIFI card from intel in that format is the 7260. With the whitelist removed, you can install a card from any manufacturer, but I suggest you to get a Lenovo card (04X6010). It'll probably save you the hassle to remove a pin or not having the WIFI LED lit during traffic. But you can install any card, as I said. So if you wish, you can buy one of those Aliexpress' AX200/210 and get AX WiFi instead of AC and Bluetooth 5.x on top of that. That's up to you; however, there is a change that you'll run into issues. Again, it HAS to be Mini PCIe; there is not slot for more modern M.2 cards.
X1C5: 7600U | 16GB | 1TB | FHD
X1C9: 1145G7 | 16GB | 1TB | WUXGA | WWAN
P14s G1 AMD: 4750U | 32GB | 1TB | PG FHD Touch
T14 G2: 1145G7 | 32GB | 1TB | FHD
Re: X230 Bluetooth?
BCM20702A0 is the USB Device ID of the Bluetooth adapter. A quick web search led to this page from Microsoft's support forums:
https://answers.microsoft.com/en-us/win ... 9160c0f5e5
It links to this particular driver: https://www.catalog.update.microsoft.co ... 04.1%20USB
Hopefully it works on your X230!
X230 1440p backlight dead
by apojoga » Wed Nov 01, 2023 4:57 pm » in ThinkPad X230-X280 / X390 Series - 2 Replies
- 1836 Views
Thu Nov 02, 2023 1:41 am
X230 - what SSD will best fit in the WWAN slot?
by br1anstorm » Tue Nov 14, 2023 3:59 pm » in ThinkPad X230-X280 / X390 Series - 15 Replies
- 6060 Views
Last post by br1anstorm
Wed Nov 15, 2023 6:17 pm
- 1 Replies
- 1903 Views
Last post by TPFanatic
Tue Nov 21, 2023 9:31 am
- 0 Replies
- 1315 Views
Last post by JPOESQ
Thu Nov 30, 2023 9:08 am
