I'm trying to add Ethernet capability to my ThinkPad X1 Yoga (2nd), I think model 20JD. Wondering whether it's better to use USB-C, USB3.0, or the dedicated port. Don't have any known need for gigabit but I guess I could get it.
ThinkPad USB3.0 to Ethernet Adapter (4X90S91830) C$23.99
Lenovo USB-C to Ethernet Adapter (4X90S91831) C$27.99
ThinkPad USB 3.0 Ethernet Adapter (4X90E51405) C$30.04
ThinkPad Ethernet Extension Cable (4X90F84315) C$24.69
If not the latter, is it reasonable to tie up a USB port for just the network, or better to get a multi-function adapter? I think I have 2xUSB-C and 3xUSB3.0, both USB-C in use (for power and DVI) and one USB3.0 taken by a 7-port hub. So I have 1-2 free USB3.0 and 0 free USB-C, and don't think I need more at this time, but would add if it's a good idea.
OTOH I see really cheap no-name adapters on Amazon for C$10 and up (USB2.0-10/100, or USB3.0-gigabit).
So my questions, for which I haven't been able to find answers:
- Is there any benefit to using the dedicated Ethernet-ish port?
- Could a USB3.0/2.0 adapter work on the hub, or would it need to be directly in a USB port?
- Is there any real benefit to getting gigabit adapter (and upgrading other hardware)?
Thanks for any guidance on the best way forward.
=aw
Thinkpad X1 Yoga (2nd): ethernet adapter?
Re: Thinkpad X1 Yoga (2nd): ethernet adapter?
It's Intel LAN, and the generic adapter are not. If you find Intel LAN more reliable, that is a possible advantage.
It can, if there is enough power to the hub.
If you use Ethernet, then yes.
I think I worded my question badly. I have a Cat5 cable to my office upstairs, where my old networked printer is connected. There's also a hub or switch (not sure which, have to check) and a cable I used sometimes on my X220.If you use Ethernet, then yes.
The WiFi signal isn't great, and I'm sure I should switch the X1 Yoga to a wired connection. I assume the dedicated Ethernet extension cable is gigabit, and if I go USB I have a choice of gigabit or 10/100. The savings on the latter are just a few bucks, but I'm sure I won't get any benefit from a gigabit adapter unless I replace the 100' Cat5 cable with Cat6, is that right? And then I'm not sure I'd benefit much from gigabit as I'm not moving massive amounts of data around the network.
So really the question is, if I choose a solution where there's a choice of 10/100 or gigabit, is it worth replacing the 100' Cat5 cable with Cat6, in my situation?
=aw
CAT5 is limited to 10/100, CAT5E can do Gigabit, but performance may vary depending on cable length and quality.
There is no reason to get any hardware that does not support Gigabit these days, but whether to bother with replacing your existent infrastructure depends on how often you actually use it and for which amounts of data.
FS: Thinkpad x1 yoga 2nd gen OLED 16gb/512gb touch $400
by db999md » Tue Dec 26, 2023 9:25 am » in Marketplace - Forum Members only - 3 Replies
- 1769 Views
Last post by db999md
Sat Feb 24, 2024 11:42 pm
Thinkpad X1 Yoga Gen 4 SSD compatibility
by bluewaterrocket » Sun Dec 03, 2023 8:24 pm » in ThinkPad Yoga - 1 Replies
- 2467 Views
Mon Dec 04, 2023 1:43 am
- 2 Replies
- 1788 Views
Last post by KALAM1TY
Wed Jan 17, 2024 9:50 am
- 0 Replies
- 4070 Views
Last post by bjain29
Mon Nov 20, 2023 9:28 am
