I recently immigrated to Win-10. Previously, I was using Linux.
After I transfer all my personal files from Linux to Win-10, I noticed all my Chinese files have wrong file names.
Instead of showing the Chinese character in the file names, it shows giberish characters.
My Win-10 does have Chinese fonts. I am able to use F2 to rename the Chinese files with Chinese characters. But there are hundreds of files, and I don't want to manually go to each one to fix the file names.
English filenames are all correct.
So, it seems like the Chinese file names got screwed up doing the immigration from Linux to Win-10.
Anyone ran into this problem before?
File name font problem (from Linux)
Re: File name font problem (from Linux)
Welcome to "Encoding Hell".
What exactly did you do? What do you mean by "transferred files from Linux to Windows"? Did you copy them from one partition to the other? Or to a different hard drive? Or do you just mount the same storage volume on different operating systems and file names show differently?
I didn't pay attention to the filenames when transferring the files over to Windows. I copied the entire user home folder.dr_st wrote: ↑Sun Dec 05, 2021 1:40 amWelcome to "Encoding Hell".
I just did "cp -rp /home/euless /mnt/"
I did one of the following (can't recall which way)...
(1) While in Linux, I mounted a Fat32 USB Thumbdrive, and copied the files into it. Then in Win-10, copy the files from Thumbdrive to the Win-10's NTFS partition...or
(2) While in Linux, I mounted the Win-10's NTFS partition (using ntfs-3g and fuse), and then copy the files over to the mounted partition with "cp -rp".
I probably did (1).
According to this:
https://docs.microsoft.com/en-us/window ... file-names
NTFS uses Unicode for file names while FAT32 partitions use OEM character sets, which is more prone to causing confusion.
I would suggest you try a variation of (1), but use an NTFS-formatted thumb drive.
updating T480 bios without Windows (I use Linux)
by redglow » Fri Nov 03, 2023 3:15 am » in ThinkPad T430-T490 / T530-T590 Series - 25 Replies
- 30911 Views
Last post by redglow
Tue Nov 14, 2023 1:00 pm
thinkpad t440p Linux trackpad + trackpoint not working.
by jaggreaney » Thu Nov 09, 2023 2:54 pm » in ThinkPad T430-T490 / T530-T590 Series - 1 Replies
- 3134 Views
Thu Nov 09, 2023 11:48 pm
- 4 Replies
- 5457 Views
Last post by marttt
Mon Jan 15, 2024 2:15 am
Using legacy Ubuntu Linux distribution with R51e
by lukee » Sun Jan 21, 2024 4:21 pm » in Linux Questions - 6 Replies
- 1619 Views
Last post by lukee
Thu Jan 25, 2024 2:43 pm
