Thinkpad 25 - Early failure symptoms? (probably similar to T470)
T25 Anniversary/Retro
#1 Post by dr_st » Mon Jul 24, 2023 1:07 pm
My Thinkpad 25 stayed docked and unused for 3 weeks while I was on a family vacation.
Turned it on for the first time - no POST, melodic beep symptoms. The HMM instructs to download a phone app to analyze the audio signal and convert it to an error code, but neither the Google Store nor the App store list it, and when I tried to install through the weblink, it told me it was not compatible with any of my phones. :?:
So I tried the "reset hole" in the bottom cover after disconnecting the external battery. Low and behold, the laptop booted.
Next day - wouldn't come out of Standby - rebooting yields the same beep symptoms.
The following day - no POST, but different symptoms - stuck in POST loop: LED and keyboard light come up, screen blank, PC restarts and all over again, until forced off with power button.
Today - suddenly turns on and works again.
I assume something is going out in the POST circuitry. I wonder if it can be remedied without motherboard replacement.
TPFanatic
Re: Thinkpad 25 - Early failure symptoms? (probably similar to T470)
#2 Post by TPFanatic » Mon Jul 24, 2023 1:27 pm
Can you try Bluestacks Android Emulator and see if you can run the App with it on PC?
https://www.bluestacks.com/download.html
https://play.google.com/store/apps/deta ... tics&pli=1
#3 Post by dr_st » Wed Jul 26, 2023 12:11 am
That's a good idea. I will try it if I hit the melodic beeps again.
#4 Post by dr_st » Tue Oct 24, 2023 3:30 pm
An update to keep track of things:
No issues for ~3 months (from the day of the last post).
Today, removed it from the dock (while in standby), tried to wake it up (on battery). It crashed, then got this again:
After about 5 such cycles I plugged in the power cable (to the USB-C port, if that matters), and it booted on the second try.
Still no recurrence of the beep symptoms.
#5 Post by dr_st » Sat Apr 20, 2024 11:57 am
I got the beep codes again, and this time was able to download this to my phone:
Lenovo PC Diagnostics 2.0
It gave the error code 0001: Reset error (platform reset not de-asserted).
Recommendations:
1. Remove the ac power adapter and the removable
battery if your computer has one. Then, reset the
computer by doing one of the following:
• For models with the emergency-reset hole,
insert a straightened paper clip into the
emergency-reset hole. Wait for one minute.
Then, reconnect all power resources and restart
the computer.
• For models without the emergency-reset hole,
press and hold the power button for about
seven seconds. Then, reconnect to all power
resources and restart the computer.
2. Replace the system board (service provider only).
Did neither of this, as I was going on a trip. A few hours later it booted just fine without me having to do any work on it.
Oh well, I guess I'll be using this thing until the symptoms become unbearable, and then start diagnosing it. Probably will end up with a system board replacement; good thing the TP25 takes T470 system boards without any changes, so there shouldn't be a shortage of them (unlike keyboards and some of the chassis parts).
#6 Post by RealBlackStuff » Sun Apr 21, 2024 12:38 am
If you are a regular T25 user, you should buy a spare mobo now and be prepared...
By the time it really happens, they may no longer be available!
micrex22
#7 Post by micrex22 » Wed May 01, 2024 6:53 pm
There's also always the T480-T25 FrankenPad: https://www.xyte.ch/mods/t25-frankenpad ... frankenpad
Edward Mendelson
**SENIOR** Member
**SENIOR** Member
#8 Post by Edward Mendelson » Thu May 02, 2024 8:00 am
That site hasn't been updated since 2022 and the most recent post is an apology for lack of progress.
TPFanatic
#9 Post by TPFanatic » Thu May 02, 2024 8:49 am
I think the idea is folks can DIY it. When I tried sourcing parts for a simpler t470 conversion I couldn’t find a power button cable , so unless I’m missing something obvious it takes sacrificing a 25 to build a frankie.
#10 Post by dr_st » Thu May 02, 2024 10:08 am
Frankenpads aside, the point is, as far as I understand, is that T470 and TP25 motherboards are identical, so a failed TP25 can be revived with any plain old T470 board, which are far more common.
TPFanatic
#11 Post by TPFanatic » Thu May 02, 2024 10:40 am
That is the truth.
All it takes is the official EC flash for any t470 board to adapt to the 7 row.
H-Atkinson
#12 Post by H-Atkinson » Mon Jun 03, 2024 8:56 am
You don't even need to flash the T470 EC for the 7-row to work, it has the necessary matrix in-memory already. The T480 requires a flash via JTAG.
P1 Gen 5
P52
T25 Anniversary
Many more as well!
TPFanatic
#13 Post by TPFanatic » Mon Jun 03, 2024 9:20 am
I had to update my T470 to recognize the 7-row properly, I guess my T470 came with an old version that lacked the compatibility.
#14 Post by dr_st » Mon Jun 03, 2024 2:09 pm
Indeed. Support for TP25 has been added in UEFI 1.39 / EC 1.25. Since that version, the systems share the same BIOS image.
theterminator93
#15 Post by theterminator93 » Tue Jun 04, 2024 3:41 pm
Was this process ever expanded upon for replication? I've been living with my T480 FrankenPad function keys being mislabeled, but it would be quite the cherry on top if it could be fixed finally.
The recovery sets guy
Return to “Thinkpad T25 Anniversary/Retro”
