Hello All,
I am still very happy with the T70 which I have been using for the past few years. Does anyone know what happened to LCDFans? I messaged them again to order another board but they never responded...
Anyhoo, I have recently wanted to attach a HDMI monitor to the T70, specifically it is actually the monitor connection of the "Wacom One" entry level graphics tablet. The tablet runs in regular HD (1080), not 4K. I have tested the tablet with another computer that has standard HDMI, and it works great. I have also tested the displayport connection on the T70 with a 4k displayport monitor, and that works great. However, I am having trouble converting the mini-displayport to HDMI with any success. I have so far tried two cables from online, both work as if there is no connection made. There is no log in dmesg and no signal detected on the display. Also, most of the cables I try to buy are listed as "for macbook pro" or "for windows surface" -- I thought the mini-displayport was a defined standard, and it didn't matter which company manufactured the device, but I could be mistaken. Anyway, if anyone has some idea why this might not be working I would appreciate your insight.
Thanks much!
mini DP to HDMI -- explanation?
Re: mini DP to HDMI -- explanation?
Not sure about the hardware you have, but for HDMI conversion to work a passive adapter, you need what's called DP++:
https://en.wikipedia.org/wiki/DisplayPo ... ode_(DP++)
Otherwise you'll need an active adapter.
R
R
mDP to HDMI usually works if it's a Thunderbolt 1 or 2 port.
My X62s has mDP and mini-HDMI, but it has no thunderbolt support. The mDP only works when going to DP or VGA.
mDP -> HDMI or mDP -> multi adapters don't work.
So I ended up finding, as you mentioned, that it works with VGA hub not HDMI passive adapters. Luckily, after getting specifically an 'active' adapter from rosewill, all was well.
Thank you for the suggestions.
T440p + Ultra Dock, but dock video out (HDMI) not working
by Arf the Lab » Sat Nov 04, 2023 6:58 pm » in ThinkPad T430-T490 / T530-T590 Series - 6 Replies
- 4617 Views
Mon Nov 06, 2023 1:39 am
I look for an 2nd Opionion if I found the Manufacture of the HDMI Matrix Switch
by Boy2006 » Sat Feb 24, 2024 7:02 am » in Off-Topic Stuff - 0 Replies
- 178 Views
Last post by Boy2006
HDMI to USB cable recommendations - please
by ap63 » Wed Mar 13, 2024 5:24 pm » in ThinkPad T60/T61 Series - 5 Replies
- 323 Views
Last post by ap63
Sat Mar 16, 2024 5:40 pm
Building a mini game console/media system
by ThinkPad560X » Mon Nov 06, 2023 12:38 pm » in Off-Topic Stuff - 0 Replies
- 1919 Views
Last post by ThinkPad560X
