Link: https://github.com/lulujyc/51nb-T70-OpenCore
Install macOS on your 51nb T70 frankenpads.
Requirement
Latest 51nb BIOS (20180115) with a working ME.
Compatibility
Motherboards
3rd Batch with i7 7820HQ: The main model this configuration was developed with and for.
1st/ 2nd Batch with i5 7300HQ: Compatible in theory. Not tested.
1st/ 2nd/ 3rd Batch with i7 7700HQ Compatible in theory. Not tested.
Test Batch with Skylake CPU Change your Graphics config.
Post-installation tweaks
A few required or otherwise useful steps to take on a running macOS system on your ThinkPad:
Using your own serial number
Just generate a new set with Clover Configurator and you're good to go
Disabling Power-related Settings
In order to achieve a stable sleep, you're responsible of disabling the following:
Power Nap (if available)
Wake for Internet Access
tcpkeepalive (hint: sudo pmset -a tcpkeepalive 0)
Brightness Control
Use Brightness Slider from App Store. Partially works but it's inverted. Unfortunately native brightness control isn't supported at this moment, interested developers might want to take a look at the DSDT and PNLF.
Middle Button Scrolling
Use Smart Scroll.
The TrackPoint & Sleep Experiment
Using VoodooPS2, whether acidanthera or RehabMan's, will have 3 types of different results that happen randomly on each cold boot: TrackPoint only, TrackPad only, and Both.
When TrackPoint is made working by VoodooPS2, Wake from Sleep will NOT work, resulting in a system-wide panic.
However, when TrackPad is only in use, Wake from Sleep will work. The TrackPad is 1-finger only.
A better solution is using the legacy ApplePS2SmartTouchPad driver, which allows ONLY TrackPoint to work, but the Wake issue is fixed this way.
The default way is VoodooPS2 as ApplePS2SmartTouchPad might not work in future macOS updates. You can disable all VoodooPS2-related kexts and update the config.plist with Latest ApplePS2SmartTouchPad
51nb-specific issues (aka: reboot after sleep blackscreen)
This is a known issue among every single 51nb ThinkPad hackintoshes that I own: X62, X210 and T70. Even under Windows, sometimes the same issue can still be repeated. The workaround has not been found and the only temp fix is to press Fn+F4, wait for several sec, then press power key after the OS entered userspace. Problem is caused by 51nb's faulty ACPI implementation.
X2100 (which sadly I don't own), however, doesn't seem to have this issue. The backlight implementation on X2100 also seems to be very standard. The difference between the old and new implementations is still not found.
What works
Full hardware acceleration
Audio
Battery reading and charging recognition
USB-A ports
CPU Temperature and voltage/wattage reading
Sleep
Mini DP and VGA output
What's untested
Hibernation
What's not yet working
Native Brightness Control
Full UltraNav implementation (reason: bad BIOS support)
51nb specific issues
What will never* work
Fingerprint
* Not unless someone decides to make custom kexts for these, of course.
Credits
https://github.com/51nbT70CLOVER/51nb-T70-Hackintosh for providing T70 battery and several other fixes.
51nb ThinkPad T70 OpenCore Hackintosh
X61HK (8250u, SXGA, 16+512+1t, macOS)
T4200s (10510u, 1080p, 16+256+1t, macOS)
WTB: any 51nb modded motherboard.
by narutorunner » Sat Nov 04, 2023 1:57 pm » in Marketplace - Forum Members only - 0 Replies
- 1655 Views
Last post by narutorunner
greetings from 51nb guys, sending by T700
by orionsnow » Sat Dec 02, 2023 7:30 am » in 51nb and other modded Thinkpads - 4 Replies
- 2209 Views
Last post by BillMorrow
Sun Dec 10, 2023 5:36 pm
Thinkpad 755 HDD reformat/factory reset
by getarest2000 » Wed Oct 18, 2023 8:30 pm » in Off-Topic Stuff - 6 Replies
- 3999 Views
Last post by Edward Mendelson
Fri Oct 20, 2023 9:16 am
Thinkpad T400 Audio issues
by Flameboi420 » Thu Oct 19, 2023 12:59 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 2356 Views
Thu Nov 02, 2023 7:10 am
