no 1802 T60....Found....
GACrabill
Re: no 1802 T60....Found....
#31 Post by GACrabill » Wed Jan 11, 2012 9:33 pm
RealBlackStuff wrote:There are just 2 T60 BIOS versions, one for 4:3 and one for WideScreen!
All 4:3 T60 use the same BIOS, currently V1.29
This Lenovo site says V2.27 dated "25 Apr 2011" for all 4:3 T60 models :
http://support.lenovo.com/en_US/researc ... MIGR-62928
#32 Post by RealBlackStuff » Wed Jan 11, 2012 11:29 pm
You are correct, I mistakenly showed the T43 number... :oops:
rekoh40567
#33 Post by rekoh40567 » Sat Jan 14, 2012 4:17 pm
cant find he bios anywhere.. need one without whitelist for
IBM T60 1951WHS
Please email me/PM me :)
denton
#34 Post by denton » Wed Feb 08, 2012 10:30 am
Looking for the same thing - T60p 79ETE6WW
mcsound
#35 Post by mcsound » Wed Mar 07, 2012 3:45 pm
T60/T60p (4:3 displays only) latest actual mоddеd biоs is here:
Flash from Windows (32-bit only!): http://www.technosphere.in.ua/diff/ibm/t60-x86-227.zip
Flash from CD: http://www.technosphere.in.ua/diff/ibm/t60-cd-227.iso
TP X61s 7668-CTO C2D L7500 XGA Ext. DVD-RAM 9-cell (Stand-by)
TP T60p 2007-YS3 C2D T7600 3Gb RAM 120Gb SSD ATI v5250 SXGA+ Ultrabay DVD-RAM+HDD 750Gb 9-cell
misfit
#36 Post by misfit » Thu Apr 12, 2012 9:29 pm
mcsound wrote:T60/T60p latest actual mоddеd biоs is here:
Thanks for that. Is that for a 15" 4:3 T60 [2007-7KU]?
I love my T60 and would hate to brick it. However it'd be nice to have 'n' wireless.
Thanks.
Shaun.
T60 2007-72U [T7400, UXGA FV]
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
T42 2374-M97 [SXGA+]
R51 1829-E5C [FV]
R40 2723-BAM [SXGA+]
R40 2723-26M
X32 x 2 2672-CM5/W58
X31's x 8 Four working.
X30 2672-4HM
X24 2662-FMT
Etc.
GACrabill
#37 Post by GACrabill » Thu Apr 12, 2012 10:46 pm
misfit wrote:Thanks for that. Is that for a 15" 4:3 T60 [2007-7KU]?
That should be the 4:3 version ... note the "227" ... 2.27 is the latest square-screen BIOS whereas the latest widescreen BIOS is 1.19.
The "227.iso" file is the exact same size as the .iso I used for my 15" 4:3 T60 .... though it has a different filename and is hosted at a different site.
misfit
#38 Post by misfit » Fri Apr 13, 2012 1:17 am
GACrabill wrote:That should be the 4:3 version ... note the "227" ... 2.27 is the latest square-screen BIOS whereas the latest widescreen BIOS is 1.19.
Thanks for that. Now.... Is that enough confirmation to risk my beloved ThinkPad? It'd be nice to hear from someone who's used it, or get access to a known-good 'no 1802' modded BIOS...
Shaun.
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
R51 1829-E5C [FV]
R40 2723-26M
X30 2672-4HM
X24 2662-FMT
Etc.
thorcik
Odp: no 1802 T60....Found....
#39 Post by thorcik » Fri Apr 13, 2012 12:36 pm
Would be nice to know, I've got a spare 4965 card I could use ;)
T60/T61 2637-AB6/8895-W4M, UXGA, T9300, 8GB RAM, Vertex3, Intel WiFi Link 5100
R61 7649-W1Z, T7250, Intel 4965
misfit
Re: Odp: no 1802 T60....Found....
#40 Post by misfit » Fri Apr 13, 2012 7:44 pm
thorcik wrote:Would be nice to know, I've got a spare 4965 card I could use ;)
I bought an Intel WiFi Link 5100 card that came from an R500 that I'd hoped would work without a kludge. :-) Alas, it's not so, 1802 comes up when I fit it.
Hopefully someone will give us a link to a modded BIOS that's known good (or even the file).
Shaun.
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
R51 1829-E5C [FV]
R40 2723-26M
X30 2672-4HM
X24 2662-FMT
Etc.
GACrabill
#41 Post by GACrabill » Fri Apr 13, 2012 8:50 pm
misfit wrote:Hopefully someone will give us a link to a modded BIOS that's known good (or even the file).
Another option is this one :
http://www.bios-mods.com/forum/Thread-I ... 0-SLIC-2-1
Posted by a BIOS-Mods Super Moderator ... downloaded 75 times with no complaints posted.
But, I would use the previously referenced .iso file before using the above link which is a Windows phlash mechanism.
misfit
#42 Post by misfit » Fri Apr 13, 2012 9:56 pm
GACrabill wrote:Another option is this one :
Thanks for that. I've downloaded the ISO but will wait a while longer before running it as I haven't bought my new wireless router yet. (It's still a pain when I take my TP out to not have N but I'm not planning on taking it out for a week or two yet.)
I actually have several cards that support N but the one I tried is a) From a ThinkPad and b) Has only two antenna nipples. My T60 only has two antenna so that's a good match (although I could run a third under the palm rest maybe... I wouldn't want to try putting it in the lid).
The other cards I have are out of Tosh lappies and have three nipples.
Shaun.
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
R51 1829-E5C [FV]
R40 2723-26M
X30 2672-4HM
X24 2662-FMT
Etc.
mcsound
#43 Post by mcsound » Sat Apr 14, 2012 3:51 am
Download links mentioned by me above are for squared 4:3 15" Thinkpad T60/T60p. I used one for flash under Windows and it works as it should (actually i'm writing this reply from my healthy and happy T60p now).
For those who is afraid of using these BIOS'es, - I didn't do them by myself, but got them from reliable sources over the internet and just uploaded to my web-site so they can be available for the community as long as possible. Almost all other sources for these files are broken now.
Hope this info helps.
misfit
#44 Post by misfit » Sat Apr 14, 2012 4:01 am
mcsound wrote:Download links mentioned by me above are for squared 4:3 15" Thinkpad T60/T60p. I used one for flash under Windows and it works as it should (actually i'm writing this reply from my healthy and happy T60p now).
Ok, thanks mcsound, I've downloaded both versions and will likely use one next week, probably the ISO, if nothing else comes up. :)
Shaun.
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
R51 1829-E5C [FV]
R40 2723-26M
X30 2672-4HM
X24 2662-FMT
Etc.
#45 Post by RealBlackStuff » Sat Apr 14, 2012 10:32 am
Personally I would NOT apply this BIOS that GACrabill mentioned (http://www.bios-mods.com/forum/Thread-I ... 0-SLIC-2-1).
He may be a Supermod on that forum, but after reading up on a few mods that he has made (a meal of), he is IMHO "in the land of the blind, OneEye is king".
Also, he does not even seem to be able to combine both Slic and NoWhitelist in one BIOS. A highly suspicious (South-American?) character. :BAAAD!:
OTOH, I have applied the MyDigitalLife BIOS (as mentioned by MCSound, and stored a.o. on technosphere several times with great success. YMMV.
misfit
#46 Post by misfit » Sat Apr 14, 2012 6:55 pm
RealBlackStuff wrote:Personally I would NOT apply this BIOS that GACrabill mentioned (http://www.bios-mods.com/forum/Thread-I ... 0-SLIC-2-1).
Thanks Dom, that's pretty much exactly what I needed to know and was hoping to hear.
Best,
Shaun.
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
R51 1829-E5C [FV]
R40 2723-26M
X30 2672-4HM
X24 2662-FMT
Etc.
larch
#47 Post by larch » Fri May 04, 2012 3:47 am
Hi All. I have T60p widescreen with original BIOS v1.19 but only G wlan card. To replace wlan with N card like Intel 5100N i need modification bios, but all i found was a bios to 4:3 model, all other links are dead.
I try to modificate bios manually with instructions from Zender, but i have an error on decompressing bios v1.19 .rom file
Сan anyone to upload bios v1.19 or earlier with no-whitelist modification (with slic 2.1 it would perfect)?
RealBlackStuff wrote:Here you go: T60 WS BIOS
Tested, All Worked. Thanks again!
#48 Post by RealBlackStuff » Fri May 04, 2012 6:22 am
the leader
#49 Post by the leader » Sat Sep 08, 2012 3:30 pm
Just an update, I used the iso to flash my T60 square and it went fine. There was an error message after rebooting but I just saved the settings and everything boots up fine everytime after. I also installed a intel 5100 wireless card after the bios update and it installed fine.
ji2o0k
#50 Post by ji2o0k » Fri Nov 04, 2016 11:57 pm
My apologies for bumping on an old thread but I am also looking for a T60 WS modded BIOS with whitelist removed to allow other types of wifi cards.
The file seems to be called Lenovo_T60_7iuj17us_LENOVO_SLIC_SSV2_WL_removed.rar but unfortunately the previous link is no longer active:
mediafire.com/download.php?sp1l11i1xpsiw41
Any help is appreciated...TIA!
Update - looks like I found it (I think) - found here:
https://forums.mydigitallife.info/threads/5866-LENOVO-(IBM)-Bioses-especially-Thinkpad/page611?p=814979&viewfull=1#post814979
Users browsing this forum: el-sahef and 26 guests
