RTFMsimpic wrote:Where is the CMOS battery? The one under the main battery? How to remove it?
Restructuring T23
Re: Restructuring T23
To remove CMOS battery, first remove main battery, remove single screw holding CMOS battery and lift out of socket. Putting it back is a little tricky, I use a small screw driver to push the connector into the socket.
@simpic: Please note that most of the more trivial questions can easily be covered by simply reading the fine documentation provided by Lenovo. It is sufficiently detailed and illustrated to answer most hardware related doubts. You have already been provided with a valid link to the mighty HMM earlier in this thread, so please just follow it and enjoy the fact, that even the questions you didn't ask yet are already answered.
As already pointed out earlier by RealBlackStuff, you will find the PDF Hardware Maintenance Manual (HMM) for free download at support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-4UYM3F. Go get it and you will be rewarded with an astonishing read.
Thank you for your reply and sorry for my stupid question.
I did search "CMOS" on manual but i could not find it out! Have a look and you will figure out.
Anyway i understand where it was thanks to your reply.
I followed your instructions and i solved my problem!
Thank you very much
Thank you very much
Glad to hear your problem has been resolved. Thanks for posting back with an update.
My Laptop Collection:
IdeaPad Z570, 8gb RAM & Win 7 Home Premium / Win 8.1 Pro
Toshiba A75-S206, 1.5gb RAM & Windows 7 Home Premium
ThinkPad T-22 (Formerly a T-20), 512mb RAM & Win XP Pro
Hello again!
I have another question for you
How to enable the 4 buttons at the top of the keyboard (on Ubuntu)?
I mean ThinkPad button and volume buttons...
Thank you.
PS: Is it possible to add function for enable/disable wireless?
Thank you.
In searching around for Ubuntu apps for a T23 I came across the Thinkpad Button program for the on screen display of the volume control. I have posted the link below. I'm not a Ubuntu user so I am not familiar with how it is used.simpic wrote:Hello again!
http://www.nongnu.org/tpb/
You should posting any additional questions regarding Ubuntu and the T23 in the Linux forum. That maybe a better venue in which to connect with those familiar with Ubuntu and the T23 system. Here is the link to that forum.....simpic wrote: PS: Is it possible to add function for enable/disable wireless?
http://forum.thinkpads.com/viewforum.php?f=9
It worked thank you very much!
...but it does not interrelate with the software panel for audio.
I mean that now i have 2 ways to adjust volume and they are not synchronized.
Is it normal?
For the other question i'm going to the Linux forum, thx
Is it normal?
Remarkable Screen Quality on T30 and T23
by Sudevan » Tue Feb 07, 2017 6:57 pm » in ThinkPad T2x & T3x Series - 12 Replies
- 1714 Views
Last post by FryPpy
Fri Feb 10, 2017 11:54 am
- 5 Replies
- 507 Views
Mon Mar 20, 2017 1:03 pm
Linux distro for Thinkpad T23 in 2017
by gnutemberg » Thu Mar 30, 2017 10:23 am » in Linux Questions - 6 Replies
- 706 Views
Last post by jaspen-meyer
Tue Jun 20, 2017 2:33 pm
- 3 Replies
- 176 Views
Last post by Raidriar
Fri Jun 09, 2017 10:20 pm
