Best way to accelerate graphics display performance on T60p?
Re: Best way to accelerate graphics display performance on T60p?
#61 Post by dr_st » Tue May 01, 2012 3:07 am
Thank you for nitpicking.
nandaiyo
#62 Post by nandaiyo » Thu Jun 28, 2012 6:27 pm
Not sure if it's the flash update, but here are my results:
FPS Low: 32
FPS High: 39
T60p, T7600 CPU, ATI 5200, Win7 ultimate 64-bit, 4GB Ram (3GB Usable), 14.1" SXGA+ 1400x1050, Flash ver 11.3.300.262.
T60p 2008JH9 - 14.1" SXGA+, T7600, 4GB, 500GB HDD, Win7Ultimate64, T61 HSF
ScottWitte
#63 Post by ScottWitte » Wed Aug 15, 2012 11:18 am
Quick update: I replaced my T7600 CPU with an overclockable T7600G. At first I got it to run stable at 17x clock multiplier vs the 14x standard for the T7600. Later that locked up and I had to fall back to 16x. Others claim to run stable at 18x so I need to figure out what I am doing wrong. Also upgraded the cooling system using most of the tricks suggested on the forum but it still gets wicked hot (90°+) so more work needed there.
Results: At 17x I got a solid 30+ fps in my test with my screen resolution of 1600x1200. At 16x I'm getting 28-30 fps. So, overall performance is as expected and just sufficient for what I needed, especially since I usually end up presenting on a HD TV monitor which forces my resolution to something like 1400x1050 and performance is much better at that lower resolution as we have seen earlier in this thread.
Scott Witte
http://www.TourDeForce360.com
http://www.ScottWitte.com
T60P T2500 T7600, 2GB 4GB, V5200, 500Gb/7200rpm, 15" UXGA
#64 Post by dr_st » Wed Aug 15, 2012 11:57 am
ScottWitte wrote:Quick update: I replaced my T7600 CPU with an overclockable T7600G. At first I got it to run stable at 17x clock multiplier vs the 14x standard for the T7600. Later that locked up and I had to fall back to 16x. Others claim to run stable at 18x so I need to figure out what I am doing wrong.
It's possible that you're not doing anything wrong. Different units may have different overclocking potentials.
ScottWitte
#65 Post by ScottWitte » Thu Aug 16, 2012 1:12 am
dr_st wrote:It's possible that you're not doing anything wrong. Different units may have different overclocking potentials.
Drat. You are right, of course. :(
I will take solace that with the changes I made I doubled my T60p Flash Graphics performance. It is now fast enough for my current purposes. Much thanks to all the forum members who shared their wisdom and guidance.
Scott
Scott Witte
Kasm279
#66 Post by Kasm279 » Tue Aug 21, 2012 2:24 am
RealBlackStuff wrote:The T2500 is Core Duo with 2MB L2 cache, the T7200 is Core 2 Duo with 4MB L2 cache.
Some graphics performance could improve by about 10-15% (e.g. rendering 3D), but in the end it's all relative.
If OP wants to squeeze the last drop out of the CPU, he stands a better chance with C2D.
See also this: http://www.anandtech.com/show/2056/1
Don't forget that the Core 2 line are 64-bit, while the Core line are only 32-bit. Then again, you should stick with 32-bit windows since you can't use more than 4GB of RAM anyway thanks to the chipset.
Main: Latitude E6430
Working ThinkPads: IBM 5155, 755C, 755CX, 760ED, 380Z, 600E (x3), i1420, 570E, X20, T23, T30 x3, T43, Z61t, T60p
WIP: 701c (Broken OS), 600 (LCD), PS/2 L40SX (HDD), 570 (No lid), X31 (HDD, LCD), R51 (HDD), Z60t (HDD), X60 (HDD), T400 (LCD), T43p (?)
Dead: i1420 (Mobo, Keyboard)
Kasm279
#67 Post by Kasm279 » Tue Aug 21, 2012 2:57 am
ThinkPadophile wrote: My machine fits the bill: T7200, V5200 GPU, 3GB RAM, Windows 7-64, Catalyst 10.2. I averaged 19-20 FPS, occasionally getting as high as 21 or as low as 14.
Edit: I should have added that these results were obtained with the laptop docked and displaying to an external UXGA monitor. Presumably the results would be better if I displayed to the laptop's UXGA screen.
My results are identical, with the 19-20FPS average. However, my machine has a T2500 (Core Duo @ 2.0GHz,) 2GB of RAM and an SXGA+ screen, but is otherwise the same. Also, according to Process Explorer, opera's plugin wrapper IS using some GPU http://prntscr.com/e5918/direct Perhaps those with integrated graphics could test this as well?
