selecting screen vor movie display
schmaud
#1 Post by schmaud » Mon Apr 09, 2012 12:31 pm
Hallo,
Somewhere was a software option to select on which display a video is shown. I have internal and external display in clone mode, and media player shows video only on one screen.
I believe there was an option to select on which screen this is, but I forgot where... search & and google where also not helpful.
It is not a source issue, as the problem does not occur on my x60s...
any help would be appreciated.
cheers
ralf
T42 2373-FWG (725/14.1/512)
1400 iSeries
x60s
Neil
Re: selecting screen vor movie display
#2 Post by Neil » Mon Apr 09, 2012 1:08 pm
Video Overlay is the term you are searching for. I'm almost certain it's available on only one monitor at the time. Can you switch from "clone" to "extend desktop" mode? Then you can drag your player to either monitor and maximize it.
