W520 keyboard in W530?
W530/W540 series specific matters only
crystal castle
Re: W520 keyboard in W530?
#31 Post by crystal castle » Sun May 21, 2017 4:46 pm
Turns out it's not the xx20 series keyboard that's bulging, it's the W530 palmrest. Not sure why though. I can press down pretty far on top of the palmrest on the left side, about 1 inch the left of the wifi and disk lights on the lcd bezel. I don't see obstructions or missing screws. the whole right side of the palmrest has almost no give whatsoever, as it should be I think.
Edit:
It's definitely the bezel. It looks like I might be able to pull it back down with the right sized screw. I've got a screw in there now but it's too big so it's not pulling the palmrest down far enough. All it's doing is preventing flex, which I guess is a start. I had to cut all hole through the bottom cover under the battery just to get the screw in there. Very strange.
X1C3, T430s, T400, X41
Return to “ThinkPad W530 and later Series”
