T60 and internal (mini PCI-e) SDHC slot
allex
Re: T60 and internal (mini PCI-e) SDHC slot
#31 Post by allex » Thu Dec 20, 2012 1:31 pm
I have frankenpad with T61 motherboard FRU 42W7648.
I've bought and successfully installed MR15 (cheaper that ebay, don't forget Half to Full miniCard Bracket) with 2x 32GB SanDisk microSDHC class 10 from Amazon sale (waiting for 2x 64GB).
Speeds are similar to mentioned here but sometimes after resume from sleep I see message "This device can perform faster..." and card reader works in USB 1.1 mode :( Restart solves the problem, but I can't restart so often :)
I've found similar topic at Lenovo support site: ThinkPad Mini Dock Series 3 and ThinkPad Mini Dock Plus Series 3 USB but it doesn't help.
It seems to me that device incorrectly initializes after resume. Does anybody know, is there a program that can re-initialize usb device without restart? Or I am at wrong way?
allex
#32 Post by allex » Thu Dec 20, 2012 3:57 pm
I've found that card reader is connected to
Intel(R) ICH8 Family USB Universal Host Controller - 2831
when in USB 1.1 mode. I restart the notebook. Now i see that card reader is connected to
Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
and works in USB 2.0 mode. I've surprised - connection scheme can change :) Don't have enough knowledge to explain it.
Sasho
#33 Post by Sasho » Thu Dec 20, 2012 7:20 pm
Thanks farmall, I will look into the SATA adapters. It will have to be one for SDHC cards, as I occasionally use those in my laptops as well. In fact, easy physical access to the media with the boot OS is one of the main reasons I am playing around with those cards.
aoitenshi
#34 Post by aoitenshi » Sat Jan 12, 2013 11:19 pm
so .... is it possible to mount 2 X 64GB microSD onto MR15 card reader?
I'm planning to buy the MR15 card reader and install it on my T61 (using 2 X 64GB microSD card )
Hello world.
wonz
#35 Post by wonz » Sun Jan 13, 2013 2:48 pm
quite cheap is instal a CF card in PCMCIA ... the adapter cost like 4$ and CF high capibilty and speed can be find in accepable price ;]
UPDATE
little update ... my way is not so good as i discover that PCI-1510 cardbus controler used in T60 doesn support DMA mode .... during use this CF card system slows down :(
IBM T60p 2007-FE2 @ SXGA+ IPS FV (new CCFL) @ T7200 @ T61p HS + T500 fan @ 32Gb SSD @ 100Gb UB @ Advanced-N 6200 @ BT 3.0
condition: 6 years on the frontline :D ... but i`m not ready to let go ...
x200 tablet @ 64Gb SSD @ BT 4.0
PAST: T61 7661-BM5 @ T9300
