Windows Xp missing a few things
burns334
#1 Post by burns334 » Tue Jun 12, 2012 9:26 pm
I came across a T60 with a fresh installation of Xp and it is missing 2 things that I noticed. When turning the volume up or down the graduated thermometer does not appear on the screen but the volume does go up and down and the blue Thinkpad button gets no response when pressed. Anyone no what I need to install to make these work?
TIA burns
hunterman223
Re: Windows Xp missing a few things
#2 Post by hunterman223 » Tue Jun 12, 2012 9:38 pm
This will get the hotkeys and on-screen display working:
http://support.lenovo.com/en_US/downloa ... D=DS014985
And this should take care of the ThinkPad button:
http://support.lenovo.com/en_US/downloa ... D=DS013514
IMO, you don't really need the second one. I have never found a use for it, just more bloatware.
Hunter Thompson
ThinkPad T400: T9400, 8GB, LG WXGA+, Samsung 830 128GB + WD Scorpio Black 500GB, Intel 5300agn, Win7 Pro x64
Others: IBM ThinkPad R40, Sony VAIO NR Series, HP TouchPad running CM9, Jailbroken iPod Touch 4G
burns334
#3 Post by burns334 » Tue Jun 12, 2012 9:46 pm
Thanks Hunter, I think you are right about the Thinkpad key but was really curious.
burns
hunterman223
#4 Post by hunterman223 » Wed Jun 13, 2012 12:25 am
No problem, glad I could help.
Hunter Thompson
