Thinkpad Z61M T2300 @ 1.66GhZ ID:9450
vinjeti
#1 Post by vinjeti » Tue Jun 26, 2012 8:22 pm
I have a thinkpad with the following configuration.
Thinkpad Z61m T2300 @ 1.66GhZ
Memory: 3 GB
Running Windows 7 professional
System Type: 32 bit.
I would like to upgrade my laptop to a faster processor. Is it possible ?
If possible, what would be the ideal replacement processor ?
Please help.
Vijay
underclocker
moderator
moderator
Re: Thinkpad Z61M T2300 @ 1.66GhZ ID:9450
#2 Post by underclocker » Tue Jun 26, 2012 9:39 pm
Hello & welcome to the forum (please add a location to your profile).
I've done this upgrade more than one time myself. The Core 2 Duo T7600 is the fastest that will work with that motherboard, but the Core 2 Duo T7200 is more than adequate and less than 1/2 the cost of the T7600 via eBay (currently, $40 vs. $90).
That being said, an SSD (assuming you do not have one installed yet) would be the best upgrade, even keeping your current CPU.
Search the forum for much more info.
Here is a link to my upgraded Z61m with full specifications, which I still use almost daily --> http://forum.thinkpads.com/viewtopic.php?f=21&t=100010
ZaZ
moderator
moderator
#3 Post by ZaZ » Tue Jun 26, 2012 11:16 pm
Unless you're maxing the CPU all the time, it's unlikely you'd notice a difference. I'd agree a SSD is far more likely to make your Z61 seem faster.
E7440
vinjeti
#4 Post by vinjeti » Wed Jun 27, 2012 5:30 pm
I have added my location .
Thanks for the replies.
Cheers
Vijay
vinjeti
#5 Post by vinjeti » Thu Jul 19, 2012 8:55 pm
Water spilled on my laptop and now its beeping 3 times when started. Any ideas ?
Vijay
vinjeti
#6 Post by vinjeti » Thu Jul 26, 2012 12:01 am
Hi Again,
I blow dried with a hair dryer and it started to work again.
I have another question.
Currently on I have 3GB ram. I have read somewhere that this laptop can take only a 3GB.
I want to check again if can I upgrade to 4GB ?
Vijay
#7 Post by ajkula66 » Thu Jul 26, 2012 12:51 am
The chipset limitation on these machines is 3GB.
The BIOS will "see" 4GB, but only 3 are actually usable.
vinjeti
#8 Post by vinjeti » Sun Jul 29, 2012 9:03 pm
The T7200 CPU says the Instruction Set is 64-bit
If I upgrade my laptop with the above CPU will it make it a 64 bit ?
Vijay
#9 Post by ajkula66 » Sun Jul 29, 2012 9:30 pm
Yes.
Just make sure that you have the latest - or a very recent - BIOS installed. Early BIOS versions will not boot with a Core 2 Duo CPU.
vinjeti
#10 Post by vinjeti » Tue Jul 31, 2012 12:52 am
Can someone please tell me if I can use SATA 3 or does it have to be a SATA 2 for the SSD.
And what other information do I have look for when getting an SSD.
Vijay
#11 Post by RealBlackStuff » Tue Jul 31, 2012 6:53 am
Your Z61M only supports SATA I speed, there's no BIOS mod that will change this.
Look for an SSD that is backwards compatible to SATA I, most SATA II drives will probably work (and are cheaper than SATA III).
I have my doubts about a SATA III drive running properly in a SATA I machine.
