A31p Invalid Machine Type error with software Installer
yes, i just brought it to our techs to input the info.
I saw that they use the 1.69 version too.
At first they got the same message I got. Then after a series of power off and on, he was able to input it correctly.
This is getting very interesting... I'm going to try figuring what he did.
Sean I'm going to try your method again
I'm looking for the program too; I need 1.71 or higher. Sorry for bumping this and creating a new thread in X-series forum, but I'm pretty desperate to find it. Thanks!
If you have the problem with MTM not supported and the MTM/Serial number is messed up in BIOS. With the newest version of SWI I have heard that you can add a key to your registry that will fix it so SWI will run.
HKEY_LOCAL_MACHINE\SOFTWARE\IBM\ThinkPadSoftwareInstaller\SysInfoOW
With String values "MachineType"="enter your MT here" and "ModelName"="enter your Model here"
a31pguy
- Moderator1
still having the problem.
well I make the corrections to the BIOS and put in the machine type and serial number - but I am still having this issue with trying to install IBM Access Connections 3.71 - "machine type not supported" - any ideas?
BTW - the new levono software updater works - but the software it downloads still gives me issues.
Sean you are correct it does have to be in CAPS, i didn't know about the 1S when i did it so i just entered 00 at the beginning...
SeanM wrote:Technically, the "00" should be "1S", but for the purposes of this utility I don't think it matters.
You should also hit the caps lock and do everything in caps here, last I checked if the model number was in lower case in bios, the SWI wouldn't work.
Glad to hear you're all straightened out!
Re: still having the problem.
What is your machine type and model, and how is it displayed when you look in the bios?a31pguy wrote:well I make the corrections to the BIOS and put in the machine type and serial number - but I am still having this issue with trying to install IBM Access Connections 3.71 - "machine type not supported" - any ideas?
This works!
I just tried this on my T42 (2378-FUU) and it worked. Although I would rather fix my serialnumber once & for all, this is a good workaround to get the software updater working.k2 wrote:If you have the problem with MTM not supported and the MTM/Serial number is messed up in BIOS. With the newest version of SWI I have heard that you can add a key to your registry that will fix it so SWI will run.
GrayZ
Slightly skeptical owner of a T42 2378-FUU
what format does the string values have to be in(registery hack)
i have an ibm thinkpad r40 2722-GCU with a model numer of fx-37812
this is what i did:
MachineType="fx37812"
ModelName="2722-GCU"
also could i get a copy of that program, so i could changes the serial number in the bios. the morons put the machine type in but not the serial number
this is what i did:
You should put 2722 as the MachineType and GCU as the ModelName. The r40 most likely needs the latest version of the maintenance program, which I do not have. If you pm me your email I can send you the version I have.martok13 wrote:what format does the string values have to be in(registery hack)
this is what i did:
As an update, I had to send my t42 in to fix another problem, and asked them to fix the bios while they had it. This really is the easiest (but longest) way to fix the problem.
swbuehler
I am also in need of this utility for my R51 (1830-AKU). The latest BIOS update program did have the option to update model type, but only the last three characters of it (after the hyphen). It would not let me change the first four digits.G-Man wrote:You've got an email.BTW, you can't really download it. Only IBM Service Centers and Business Partners have access to it. Hope it works.
My company swapped out the mobo last October and failed to put in the model or serial number on it before shipping it back to me, and now Software Update utility doesn't work.
stevenwbuehler@yahoo.com
SWB
CONFUSEDNEWBY
Hi
i replaced the MB in my A20m and the invalid machine type is a problem i have also.
if your program is applicable to my machine (I did not update any numbers after MB replacement), I would really appreciate it if anyone could email it to me.
thank you
seminoleman199@se.rr.com
thank you
Hello everyone:
I just got a T23 with the 'Invalid machine type' problem. I'm also showing nothing on the Serial number and Model Number in the Bios. I would appreciate if someone would email me the IBM Maintenance Utility at luisy2k@excite.com.
Cheers from Puerto Rico.....
I have the same problem, I get invalid machine type for the update, and serial and MT are blank.
. I called support but no help. The support person said you can update this info on the desktops but not the laptops.
I would be grateful for a maintance program so I can take care of this.
jgfusco3@yahoo.com,
Thanks,
Jim
jgfusco3@yahoo.com,
Thanks,
Jim
G-Man your utility is a popular one. Can you please email it to me too !
danfrenchuk@hotmail.com
thanks
thanks
My machine got serviced by the local IBM rep, and they replaced the motherboard. Even though I've complained to them that they didn't set the model/serial number, they have no idea how to do it. sigh.
Any chance I could get a copy of that utility?
snorter at genesiscollective.com
T43p, Pentium M 760(2GHz), 1GB RAM, 80GB 5400rpm HDD, 15in 1600x1200 LCD, 128MB ATI FireGL V3200, CDRW/DVDR, IBM 802.11abg wireless(MPCI), Bluetooth/Modem(CDC), 1Gb Ethernet(LOM), UltraNav, Secure Chip, Fingerprint Reader, 9c Li-Ion, WinXP Pro
CannedCorn
util
Could I also get a copy of that utility... tjb13 at duke dot edu... Does it require that you have a floppy drive... how the hell do you do it without one!
ThinkPad 770ED, T43P, X60, X61, T61, X301
proaudioguy
I would very much like to get this utility, if anyone can help I really appreciate it.
makeshiftaudio@yahoo.com
I'm also in need of the utility if I could trouble someone to send it to me. It really is somewhat surprising that it isn't more easily available.
jms@sharpe.com
Thanks much
jms@sharpe.com
Thanks much
proaudioguy
proaudioguy
Can I have it too...Pleeeeaaasssseee
Hi.
I just replaced a board in my A20m.
Could some one please send me this too.
I would appreciate it very much.
thanks.
r_tibbar@hotmail.com
thanks.
By reading all the mobo issues everyone having in that the machine type is not showing, is there any way the Hardware Maintenance Disk be posted somewhere. I know (I've heard) about the potential for it being used nefariously, but I believe it would make things easier and simpler since there are DIY'ers here. I, too, replaced both motherboards on the T22 I previously owned and the A30 I currently own. When I do the "Detect..." it gives me the wrong machine type. I'm not asking for the utility, but it would be easier to download.
A31 2652-Q3U Pentium 4-M 2GHz, 15" SXGA+IPS LCD, 512 MB PC2100, 40 GB HDD, Windows XP Pro, Sony Multi-Burner, Ultra Bay 2000 Battery, Intel Pro 2200 b/g mPCI wireless card
Invalid tar magic with tar command. Help.
by Blender » Fri Jan 06, 2017 1:35 am » in Linux Questions - 2 Replies
- 809 Views
Last post by jaspen-meyer
Mon Jan 09, 2017 2:06 am
How to look up specs for newer style machine type numbers?
by serpico » Fri Apr 07, 2017 10:27 am » in ThinkPad T430/T530 and later Series - 2 Replies
- 339 Views
Last post by serpico
Sun Apr 09, 2017 9:10 pm
Do the T430 and T440 have the old 7 digit machine types?
by serpico » Thu Apr 06, 2017 1:42 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 376 Views
Thu Apr 06, 2017 2:36 pm
- 3 Replies
- 1154 Views
Last post by Kasm279
Thu Jan 12, 2017 4:29 am
