T60 random freeze *PIC*
zenlunatic
Re: T60 random freeze *PIC*
Wow that CPU stress test is amazing. Pushed me up to 99 C
zenlunatic
So I bit the bullet and did a disassemble. I noticed two things which are linked below as pics.
A. I went a little overboard on the artic silver. I have lots of experiences with PC repair but not much thermal grease application. I made sure not to overdo it after cleaning the cpu for a second attempt.
B. The thermal pad on the Northbridge wasn't fully applied. I do not admit fault though because I had to literally add the pad to the very edge of the copper and cut with a razor to achieve full coverage (bad design)
No lockups yet but I'm still waiting. Next is a clean install and possibly BIOS updates (nothing in changelogs were related to my issues). Then out comes the plastic for a new machine.
A. http://i.imgur.com/ZJHGD.jpg
B. http://imgur.com/H80Sx
Tasurinchi
Boah... That's was really to much.zenlunatic wrote:A. I went a little overboard on the artic silver.
I normally apply a little bit less than this picture (taken from a T43p):
The end result after spreading the paste could look like this:
The above are old pics, I'm using a little less thermal compound lately, covering about 80% of the die, the heatsink will normally press the paste to cover the rest.
My two cents...
zenlunatic
Yeah that is much better than mine.
Good news is that I haven't had any lockups. I really think it was that northbridge thing. They really should have extended that copper further for a less convoluted thermal putty application.
zenlunatic
Froze again... time to move on to different hardware. This is quite dissapointing.
Tasurinchi
Have you tried a Linux Distro? You can burn a CD or install it in an USB stick and run it from there for a while. If it doesn't freeze it may point to a software rather than a hardware issue.
Have you tried running it without the battery?
That may be the culprit.
zenlunatic
I've tried without the battery and it still froze.
I haven't recognized any sort of pattern or trigger for the freeze.
Tomorrow I will be able to reinstall to a clean slate for testing purposes.
Tasurinchi
A Win clean install it's normally a lot of work until you get all drivers and stuff working. I'd really encourage you to try a Linux Distro from a CD or USB stick. You need no installation for that and you can just use internet or try any mini game to see if the Thinkpad freezes... It will be at least a quick method to check if you really have a hardware issue...zenlunatic wrote:Tomorrow I will be able to reinstall to a clean slate for testing purposes.
My 2 cents only...
zenlunatic
I know. Debian Squeeze is all I use on this machine. I can do a clean install of Squeeze tommorow or this weekend.
zenlunatic
Suprised no one mentioned the hdd. Going to do more tests on it.
ThinkPad X230 freeze problem solved
by BerFab » Wed Jan 25, 2017 4:46 am » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 670 Views
Last post by BerFab
FS: Random Thinkpad parts
by Whitieiii » Wed Mar 01, 2017 2:06 am » in Marketplace - Forum Members only - 1 Replies
- 359 Views
Wed Mar 01, 2017 7:43 am
- 0 Replies
- 2414 Views
Last post by caven.ohm
Tue Mar 14, 2017 6:55 am
- 1467 Views
Last post by Whitieiii
Thu Feb 16, 2017 7:48 pm
