Mountain Lion on X220
Re: Mountain Lion on X220
Hi all,
Anyone upgraded to Mavericks ?
I am openning a new threat for Mavericks
Manu
Manu
hi all,
thanks for this topic. My X220 now runs under W7 and Mountain Lion.
I had an issue after 10.8.5 combo update. I reinstalled AppleACPIPlatform kext in S/L/E
but I couldn't boot without "-f" flag
until I moved every kexts from /E/Extension to S/L/E with KextUtility and rebuilt the kernel cache :
sudo kextcache -system-prelinked-kernel
sudo kextcache -system-caches
I installed EasyBCD but it couldn't boot OSX on the 3rd partition : mbr chain error or buggy old EFI boot.
My partitions are /NTFS/exFAT/HFS/free
I wiped out EasyBCD, rebuilt the W7 mbr bootloader and now Chameleon does the job.
But Chameleon Wizard can not write to the PBR of a mounted partition and gives no messages. result => boot0: error
I had to copy Cham binaries (/i386/boot*) to the install-disk, boot the install-disk, launch a Terminal, unmount /dev/disk0s3 and hit "dd if=boot1h of=/dev/disk0s3 bs=4096".
Greetings,
Please see this thread running OS X Mavericks 10.9 on the X220.
I have written a guide which I hope we can work on to provide a straight-forward resource for this.
Could you put your files for the pm patch files online again? I can not patch my dsdt of 1.39 version properly. If possible, could you share your dsdt file? Thxsot_33 wrote:manuforce : now i use the latest rehabman voodoops2 1.8.8
re404 : this is what i have and is the latest version 1.39 with whitelist and pm patch (you dont need to patch AppleIntelCpuPowermanagement Kext anymore)
i suggest to remove the wifi card from your laptop then update the bios with this original lenovo bios : http://www.sendspace.com/file/zylphr
then after the reboot download this : http://www.sendspace.com/file/mmrz0f
unzip it somewhere and run FLASH.BAT
when its over shutdown the x220 and install your new wifi card (i have the dell from first post)
now you have it
hi , sendfile must have delete the files
you can d/l from here
the patched bios : http://www3.zippyshare.com/v/15189741/file.html
original : http://www3.zippyshare.com/v/44264893/file.html
edit 18/12 update new dsdt : http://www24.zippyshare.com/v/82117974/file.html
*notes :
Dsdt in Device (IGPU) has my monitor EDID inside (my screen in not the ips and i don't know if there is a different edid for ips screens , you can remove this info from dsdt if you want).
Rehabman's battery 1.50 kext now work
if you install the patched bios you have to patch only AppleRTC and install patched appleHDA for audio, FakeSMC,AppleIntelE1000e,Battery and VoodooPS2Controller kext from Rehabman.
bye
*notes :
bye
Could you repost the bios please? Trying to fix my DSDT from scratch!
EDIT: Found it
EDIT: Found it
Upgrading X220/X230 to WQHD 1440p
by nitrocaster » Mon Dec 26, 2016 6:45 am » in ThinkPad X200/201/220 and X300/301 Series - 18 Replies
- 3725 Views
Last post by crashnburn
Wed Mar 29, 2017 3:10 am
WTB: Dead X220/X230 motherboards
by nitrocaster » Mon Dec 26, 2016 5:37 pm » in Marketplace - Forum Members only - 0 Replies
- 336 Views
Last post by nitrocaster
Thu Jan 05, 2017 7:27 am
Recase a X220 into an X220i?
by T3f4l » Thu Jan 05, 2017 10:22 am » in ThinkPad X200/201/220 and X300/301 Series - 4 Replies
- 855 Views
Last post by T3f4l
Sat Jan 07, 2017 8:43 am
Replacement for X220: X260 or E470? Or something else?
by awebber » Sat Jan 07, 2017 11:48 am » in ThinkPad X230 and later Series - 13 Replies
- 1296 Views
Last post by mj0
Thu Jan 12, 2017 7:20 pm
