HELP!ScottyBoy wrote:
Basically Middleton's BIOS provides core native SATA-300 speeds, SLIC 2.1 (Windows 7 activation support) and most importantly the hardware whitelist is removed (really handy for installing non-Lenovo half-height Intel N Class PCIe Wifi Cards) - there are additional benefits as well (i.e. Ctrl+Fn keys swapping and Dual-IDA support) but they are low down in the list for me.
IF you do proceed with installing bear in mind there is the potential of the BIOS update bricking your ThinkPad...listed below is a link to the main section for the BIOS download links and assuming your X61s is a standard XGA model then you'd be looking at the BIOS available in the first line of the table.
You might want to consider reviewing the entire Middleton BIOS thread at the NBR Forum to get a handle on what's involved but it is relatively easy to get install - I generally use a bootable USB flash memory stick to get it done, as some of the systems I've worked don't have a working optical drive and/or HDD when I get them.
EDIT: B*gger! Was already answered whilst I was typing a reply and hunting out the link to the Middletion BIOS table!
I am so frustrated and wasted half an afternoon trying to flash an X61s with a new BIOS.
I do not have the X61 docking with CD Drive, but only a USB CD and some USB sticks.
USB CD drives don't work. They are recognized and boot. But then comes the error, that CD ROM drivers are not found. Not even when I manually put them on the CD before creating the ISO. Not even original IBM BIOS does work. Same error.
Seems, only ATA internal drives are recognized thru the docking station.
Now I flashed a USB stick with ISO2USB tool. No luck. Not recognized as a drive at all.
Can you tell me how you flashed the USB stick to make it bootable and recognized by the X61s?
