May as well delete the whole thread, if the original poster offended anyone...I, for one, wasn't...
Trackpoint mark on LCD?
Re: Trackpoint mark on LCD?
Hm? At this point it's probably no use to edit the original message, as it will require a recursive edit of each one who replied
X200: 2.4 GHz, 4 GB RAM, 160 GP @ RPM drive, WinVista Business 64-bit
X60s (1704-4DU): 1.66 Core Duo, 1.5 GB RAM, 100 GB @ 7200 RPM drive, WinXP Pro
T40p: 1.6 GHz, 1.5 GB RAM, 60 GB @ 7200 rpm drive, 64 MB Video, 802.11 a/b, WinXP Pro
Nonny, were you really offended by it? I can edit it if you want? I know people access it from work. I didn't think it would be a problem since I was AT work when I wrote it (and my friends at my office read it and liked it, including women). But if it offended you that much I can delete that part.nonny wrote:Consider yourself called on it. Some of us access this forum from work.
ThinkPad T42p 2373-GVU (now dead waiting for resurection) SHE IS ALIIIIIIIVE! (resurection day: 10/12/2005)
Ordered: June 14 04
Recieved: June 23 04(thanx Bill)
Win XP Pro / Ubuntu
Ordered: June 14 04
Win XP Pro / Ubuntu
You are right.. this is getting off topic. Sorry for having to put you through this. I appologize. But anyway? Anyone can think of any material other than a t-shirt fabric to put in between the keyboard and the LCD when it's closed in order for the c**t not to damage the screen?
Ordered: June 14 04
Win XP Pro / Ubuntu
Ordered: June 14 04
Win XP Pro / Ubuntu
No problem, took all of 1min. Besides, that is my duty as moderator.
Anyway, I think you have about 3 choices:
1.) Place something (fabric, paper, etc.) between trackpoint and screen every time you take it with you
2.) Change the trackpoint cap to a different style that leaves less or no print (or remove it altogether...is this an option?)
3.) Deal with it.
I am curious as to whether or not it's an issue with mine, we shall see in a few weeks.
By the way, is the mark some kind of permanent pressure mark on the screen or just a little grease? If its just dirt/oil, then maybe you should wash your hands before touching the c**t?!?
3.) Deal with it.
IBM ThinkPad T42p (2373GVU)
NEW!
Lenovo ThinkPad T60 (2007MS2)
NEW!
First of all, when my girlfriend read this she laughed her butt off! lolbenz wrote:I am curious as to whether or not it's an issue with mine, we shall see in a few weeks.
Second, it is not a grease/dirt/oil damage. It is a pressure demage.
But anyway. That's her laptop! Mine is coming soon and I am the only one that will get to play around with it!
Ordered: June 14 04
Win XP Pro / Ubuntu
Ordered: June 14 04
Win XP Pro / Ubuntu
Actually, yes, I was personally offended by your use of a vulgar sexual term for the TrackPoint.
Aside from that, the real problem is not the juvenile language. It's that some of us read the forum from work, and browsing web sites and forums that have vulgar language or graphics could get us fired.
Jane
I'm on Twitter
I'm on Twitter
vulgar sexual term? I'm sorry nonny but c****ris is not even a slang. It is a word used to describe part of the female body, just like arm, leg or even penis(male body in this casenonny wrote:Actually, yes, I was personally offended by your use of a vulgar sexual term for the TrackPoint
Ordered: June 14 04
Win XP Pro / Ubuntu
Ordered: June 14 04
Win XP Pro / Ubuntu
Hmm... maybe the problem is not the original poster's language, then...nonny wrote:It's that some of us read the forum from work, and browsing web sites and forums that have vulgar language or graphics could get us fired.
hahahaha! that was cute!G-Man wrote: and once you go Dell, you'll go to hell.(No offense).
Regards,
G-Man
Cheers
ian
- **SENIOR** Member
Unusual though it may be for me to agree with you, I do...Txiasaeia Hmm... maybe the problem is not the original poster's language, then...
Personally I have little time to spend trolling fora etc. when I'm at work, but then I used to drive an UNO
Ian at thinkpads dot com
I am not sure that is is a good idea to place something between the keyboard and the screen, I believe this can create more damage than it removes. The extra layer will simply increase the amount of surfaces which can come into contact.
As for the trackpoint, I think that there is a difference depending upon which of the trackpoints is used. Apparently the domed, rugged trackpoint ( where the center is the Highest point) causes the least amount of contact if any, whereas the inversed dome, smooth trackpoint ( the centre is the lowest point) is likely to cause the most contact.
IBM ThinkPad T43p.
IBM ThinkPad T41p.
IBM ThinkPad T41p.
I have the same problem.. I get a circular grease-mark on the screen, right where the trackpoint is. Maybe it's because I use the raised trackpoint cap, where people without the problem uses the one that is rounded downwards.
Btw: I wouldn't want to work in a place, where just looking at the word "c**t" could get you fired. Talk about a dreary/humorless place
t41p (ibm a/b/g & bluetooth) running windows 2003 server
hausman
Back to the scratches on the LCD, I'm sure I've seen something on IBM's website that says this is not covered under warranty. I can't find that statement now, but these links may be useful, even though they refer only tangentally to screen scratching.
http://www-1.ibm.com/support/docview.ws ... MIGR-52190
http://www-1.ibm.com/support/docview.ws ... IGR-4A2P54Symptom: There is a scratch-like marking on the LCD. This might be a stain transferred from the TrackPoint or from the key tops of the keyboard when the cover was pressed from the outside.
Dorian Hausman
SL500 (2746-CTO) • X61s (7666-34U) • T60p (2007-93U) • A21p (2629-HWU) • eXThinkpad (5160-087)
- 2381 Views
Last post by Cookie Guru
Sat Dec 31, 2016 6:21 pm
W520 trackpoint + buttons issue
by oeuvre » Sat Jan 28, 2017 11:23 pm » in ThinkPad W500/510/520 and W7x0 Series - 5 Replies
- 1444 Views
Last post by oeuvre
Mon Jan 30, 2017 12:13 pm
[Thinkpad 701Cs] Hard trackpoint
by WarMachine » Fri Feb 10, 2017 6:33 am » in ThinkPad Legacy Hardware - 6 Replies
- 1455 Views
Last post by WarMachine
Fri Feb 17, 2017 2:18 am
remove and clean under the trackpoint mouse buttons
by louisJ » Fri Feb 10, 2017 1:51 pm » in ThinkPad T430/T530 and later Series - 4 Replies
- 457 Views
Last post by louisJ
Fri Feb 10, 2017 3:15 pm
