Trackpoint mark on LCD?
akerman
#31 Post by akerman » Thu Jun 17, 2004 5:07 am
I have the same problem.. I get a circular grease-mark on the screen, right where the trackpoint is. Maybe it's because I use the raised trackpoint cap, where people without the problem uses the one that is rounded downwards.
Btw: I wouldn't want to work in a place, where just looking at the word "c**t" could get you fired. Talk about a dreary/humorless place :(
t41p (ibm a/b/g & bluetooth) running windows 2003 server
dclee012
#32 Post by dclee012 » Thu Jun 17, 2004 8:13 am
the way i see it.. if you're actually on the forum doing "work" (IT, etc) then vulgar stuff can be a problem. but if it's totally unrelated to your job, (you just like thinkpads, etc) then you shouldn't even be here... you should be working..
hausman
#33 Post by hausman » Thu Jun 17, 2004 8:47 am
Back to the scratches on the LCD, I'm sure I've seen something on IBM's website that says this is not covered under warranty. I can't find that statement now, but these links may be useful, even though they refer only tangentally to screen scratching.
Symptom: There is a scratch-like marking on the LCD. This might be a stain transferred from the TrackPoint or from the key tops of the keyboard when the cover was pressed from the outside.
http://www-1.ibm.com/support/docview.ws ... IGR-4A2P54
http://www-1.ibm.com/support/docview.ws ... MIGR-52190
Dorian Hausman
SL500 (2746-CTO) • X61s (7666-34U) • T60p (2007-93U) • A21p (2629-HWU) • eXThinkpad (5160-087)
