T420 build quality. Is it good after all?
Re: T420 build quality. Is it good after all?
Can´t seem to find any real review on this particular dislpay, but Sony uses it on their Sony Vaio E Series - SVE14111ELW (E14)...
You can´t change the past but you can create a better future if you change the present.
IBM
T41 2373-311 - 2GB Ram, 2Ghz
T43 2668-J29 - 2GB Ram, 2Ghz
T420 4178-ABP - 8GB Ram, i5 2520m
W510 - 16GB Ram, i7 720QM, SSD
IBM
Let's discuss the issues:
1) Size.
Newer Thinkpads are ridiculously huge. They say the bezel around the screen is so big to route more antennas (WWAN, BT, WLAN). My opinion is that you don't need to route so many cables, they could perfectly make them flat but shielded and run them behind the screen.
I believe that the real reason is that they don't want to lose the touchpad. With 14" screens and lower, there is not enough vertical space to fit a keyboard, a trackpoint and a touchpad unless you add some artificial height.
Thickness increased to fit cheaper components such as 12.7mm optical drives. What annoys me is that they removed the battery connector from the Ultrabay. In my Dell days I used to have a D600 and the modular bay battery (12.7mm tall) had like 48 Wh or so. I'm pretty sure that with modern batteries they could easily allow you to double the run time without increasing the size at all.
2) Build construction
It's a tank. It's well built, no complaints. It's made of CFRP like someone said and that's the highest quality stuff readily available today (let's just hope nanotubes hit the market soon). The lid is plastic but it's a good thing (for wireless). It does have magnesium inside to reinforce it.
Overall, the T420 is a great machine. It's fast, it has long battery life, it is built very well and ports are plenty and useful. My only complain is size.
1) Size.
Main: i5 3550, 16GB, Z68 Pro3 M, 64GB SLC, 320GB HD, GTX 650Ti, 21.5 FHD LED
T420: i5-2520m, 8GB, SSD: 64GB SLC (boot) | 128GB MLC (storage), HD3000, HD (1366x768), 6 Cell, BT, WebCam
X220: i5-2520m, 4GB, SSD: 64GB SLC (boot) | 128GB MLC (storage), HD3000, HD (1366x768), 6 Cell, BT, WebCam, FP
Mikemex does a real nice job describing the T420 there, thanks for the feedback. I've been very pleased with my T420.
Thinkpad T420 | Core i-5 2520M | 16gb RAM | 120gb Intel 520 SSD + 750gb 7200 RPM | 6300 N | Ubuntu 12.04 x64
Desktop: AMD FX-8350 (8 cores) | 32gb ECC RAM | 240gb Intel 530 SSD + 1tb 7200 RPM | Ubuntu 14.04 x64 | HP ZR24w
Previous Thinkpads: A21m, R40, X61, T410
Agreed on specific scenarios such as this. I have no use for VM's and therefore have not required the use of 16gb of RAM.wolfman wrote:It depends on your use case. For example, just last week I was prototyping a server build for work and had 3 VMs running on top of my host OS. 2 of the VM's required 3gb of RAM each and 1 of the VM's required 6gb. So that left 4gb left over for my host operating system. If you need the RAM, you need the RAM (I sold my T410 and bought the T420 specifically so I could use 16gb of RAM).
4178-6VU + Intel 520 Series 120gb + Crucial M4 256gb + 8gb RAM
WTB - T60/60p for Frankenpad build
by KroviRoz » Mon Jan 02, 2017 4:35 pm » in Marketplace - Forum Members only - 2 Replies
- 366 Views
Last post by KroviRoz
Mon Jan 02, 2017 10:21 pm
Lenovo support draws a blank on my build # / serial
by glossywhite » Fri Jun 02, 2017 8:38 pm » in ThinkPad R400/R500 Series - 12 Replies
- 601 Views
Last post by ajkula66
Tue Jun 06, 2017 7:09 pm
How to build an advanced FrankenPad
by ThinkDan2004 » Sun Jun 04, 2017 7:30 am » in ThinkPad T6x Series - 15 Replies
- 824 Views
Last post by wujstefan
Mon Jun 26, 2017 8:24 am
Remarkable Screen Quality on T30 and T23
by Sudevan » Tue Feb 07, 2017 6:57 pm » in ThinkPad T2x & T3x Series - 12 Replies
- 1752 Views
Last post by FryPpy
Fri Feb 10, 2017 11:54 am
