X61T Problem #2: Shutdown
milstein
Re: X61T Problem #2: Shutdown
#31 Post by milstein » Thu Nov 15, 2012 5:35 pm
X-Man & Fixed_Rider,
Thanks for sharing. That eBayer seller is probably a Thinkpad rebuilt ninja himself (or her??).
It has risk of shutdown when the indicator said the CPU is 80'C or above.
It's intriguing - I also assume the fan is working when I hear the noise and obviously the cooling mechanism is not functioning so well. Or is it the case that the aging of some parts of the machine is leading to the build up of heat?
At the moment, I totally want to replace it because of the noise and heat and unreliability due to random heat-related shutdown. I am thinking about X220 Tablet, but it doesn't mean that I would be really happy - because I really want a high resolution screen with at least 1050 vertical pixels. And the keyboard is totally changed since X230 Tablet : there will never be the best of both world ever again.
If this heat and shutdown problem is fixed, I can totally stay happy with my X61T for a couple few more years - I even bought a new SSD for it.
X-Man
#32 Post by X-Man » Fri Nov 16, 2012 5:57 am
milstein wrote:It's intriguing - I also assume the fan is working when I hear the noise and obviously the cooling mechanism is not functioning so well. Or is it the case that the aging of some parts of the machine is leading to the build up of heat?
Unless you can smell something burning I can't think of anything else internally capable of generating that amount of heat.
Furthermore my fan is as quiet as a mouse; there must be a reasonable probability that the noise is an indication of hitherto unidentified problems the specifics of which shall remain utterly mysterious. If I were you I’d be inclined to pony up the 20 bucks to find out!
Active: X220 Tablet (i5-2520M, Multitouch) | T530 (i7-3720QM, 1920x1080)
Retired: 2x X31 (1.6/1.7 GHz) | T60p (Core Duo 2.2Ghz, 1600x1200 IPS) | 2x X61T (1.6/1.8GHz)
#33 Post by RealBlackStuff » Fri Nov 16, 2012 7:31 am
@milstein:
check the P/N or FRU on that fan.
I have a nagging suspicion that you have an X60T fan (41V9748) instead of an X61T fan (42X4399).
