Best way to add bluetooth to T43?
amerin
#61 Post by amerin » Sun Jul 24, 2005 3:04 pm
In my T43 I added the BT antenna FRU #91P6897, Clear Plate #26R8409 and the BMDC3 #39T0022.
If you need some new screws order Screw Kit #13R2916.
Regards amerin
IBM T43 1871-4AG with IBM Bluetooth IV
Ground Loop
#62 Post by Ground Loop » Sun Jul 24, 2005 3:44 pm
On my T43, the antenna cable was a thin white coax that ran from the left LCD hinge, across the bottom of the modem/bt card, and then was taped under the modem. No problem.
The part # for the Clear Plate includes a sticker for every current T4x laptop, with every option combination. There are many.
And there is also replacement clear plate for the small power/sleep sticker on the top of the lid -- in the same kit.
Puttagee
#63 Post by Puttagee » Sat Jul 30, 2005 4:50 pm
Has anyone add the bluetooth antenna, modem CDC and clear plate to a T41 (2378dlu). I would like to add this but want to confirm the fru #s.
thinkpadz
#64 Post by thinkpadz » Sat Jul 30, 2005 9:16 pm
cool, how exactly do you do that?
I have a t610
aaronpropst wrote:
anthony wrote:...
:?: What's the excitement about Bluetooth?. Other than sync your PDA, what does it do for you? My model did not come with a bluetooth card. (Although I understand they all have the antenna) Just wondering why I would bother adding it.
TIA
Internet over cellular. I keep my SonyT610 in my pocket, and my thinkpad hooks up to it, and connects to the net. simple as hell, and there's no extra hardware (like a pcmcia card) cluttering up my puter.
t41p 5LB Gaming wonder.
Overclocked and Under-Volted to the Hilt.
Navck
#65 Post by Navck » Sat Jul 30, 2005 9:43 pm
Anyone able to comfirm if their warranty can be voided from this?
dtakias
#66 Post by dtakias » Thu Aug 04, 2005 3:34 am
hi,
i have a t43 s2668-46g , UC346UK
although i have a belkin usb bluetooth 1.2spec, i would like to ask what will i need in order to add bluetooth to my thinkpad.
also will it be the newest bluetooth spec?
cheers
nick
nirvana0001
#67 Post by nirvana0001 » Thu Aug 04, 2005 5:19 pm
I bought "Part#: 39T0022" for mine.
2008 Alienware M9750 - 17" WUXGA C2D 2.0Ghz 4GB SLI 7950GTX 100GB+200GB
2007 Sony UX280p - 4.5" SVGA Core solo 1.2Ghz 1GB Ram 40GB HDD XP Pro
2007 Macbook Pro - 15.4" WSXGA C2D 2.33Ghz 2GB X1600 256MB 120GB
dtakias
#68 Post by dtakias » Fri Aug 05, 2005 7:24 pm
ok thanks for reply.
btw the laptop has intel 2200bg network, to add latest a/b/g what card/part number will i need pls? will it has to be ibm or intel ? i am bit confused.
cheers
nick
Lenovo Thinkpad x301 2776 upgraded to 4GB PC3-8500S
IBM Thinkpad T43 2668 moded: Intel 780, 2GB PC2-4200S,100GB 7k100,IBM II a/b/g,BT,DL DVD Burner,9cell,Advanced Dock II
Toshiba Satellite Pro U200 (T7200, 2GB, 3945a/b/g, DL DVD Burner)
nirvana0001
#69 Post by nirvana0001 » Fri Aug 05, 2005 8:14 pm
dtakias wrote:ok thanks for reply.
cheers
nick
both IBM and Intel would be work. I heard the IBM wireless card is better than 2200 on t42; But i don't know is it still better than 2915 on t43.
Draxy518
Bluetooth Upgrade
#70 Post by Draxy518 » Mon Aug 08, 2005 10:40 am
Hi there,
I have an IBM T42 model # 2373-3XU
My model isn't listed as having the bluetooth antenna, but I do have the white cable labeled BT under my modem daughter card.
Does that mean that I actually do have the antenna or is the cable just there on all models anyway?
Thanks for any help!
aaronpropst
#71 Post by aaronpropst » Mon Aug 08, 2005 10:55 am
I'd imagine the antenna's actually in there.. they're pretty fixed to those wires.. so i doubt they'd lay the wire without the antenna.
only way to confirm is to open it up of course.. but my hunch is yeah.. you're good.
Puttagee
Re: Bluetooth Upgrade
#72 Post by Puttagee » Mon Aug 08, 2005 7:02 pm
Draxy518 wrote:Hi there,
I thought I saw this before (http://forum.thinkpads.com/viewtopic.php?t=14036). Making sure you get an answer :?:
Well, here goes again, not all models come with the antenna but since you have it you just need to change the Modem Daughter Card to one with BT and you're off to the races! :D
redrock
Clear Plates
#73 Post by redrock » Tue Aug 09, 2005 10:41 pm
One thing I don't see listed here is how to remove and apply the clear plates for Bluetooth ? I have a T43 so if anyone wants the other plates T41,42, etc. Please PM me.
Champ
#74 Post by Champ » Tue Aug 09, 2005 10:44 pm
yah I wondered too.. but it turns out a knife does the trict relal well. It's not that thick or sticky at all
Puttagee
#75 Post by Puttagee » Wed Aug 10, 2005 5:20 pm
Puttagee wrote:Has anyone add the bluetooth antenna, modem CDC and clear plate to a T41 (2378dlu). I would like to add this but want to confirm the fru #s.
No word on this as yet.
RogerPodacter
#76 Post by RogerPodacter » Thu Aug 11, 2005 5:18 pm
anthony wrote: :?: What's the excitement about Bluetooth?. Other than sync your PDA, what does it do for you? My model did not come with a bluetooth card. (Although I understand they all have the antenna) Just wondering why I would bother adding it.
TIA
My cell phone links to my thinkpad for internet access anywhere i have a cell signal. convieneent:)
RogerPodacter
#77 Post by RogerPodacter » Thu Aug 11, 2005 5:19 pm
heavybyte wrote:Does the T42 2378FVU have an antenna?
heavy
yes it does
redrock
CDC3 card not available !!!
#78 Post by redrock » Tue Aug 30, 2005 2:09 pm
I ordered the following from Parts web on Aug. 8th for my T43. The I got the screw kit and plate kit in a day or two. The CDC3 card was then backordered.
1 13R2916 SCREW KIT FRU
1 39T0022 CDC BLUETOOTH/MODEM COMBO 3
1 26R8409 CLEAR PLATE KIT FRU
So almost 3 weeks later I decided to call into IBM parts to see what happened with the B/O. They indicate that that part is no longer available and that they had tried to contact me (not true BTW). I asked them to send me an email indicating that and what the replacement part is ?
Does this make sense to anyone.
thanks...
redrock
0022 EOL... replacement is 0024
#79 Post by redrock » Tue Aug 30, 2005 9:18 pm
IBM Parts never called me back I had to call back into them.
They indicated that 39T0022 is out of production and the replacement is 00024. However the description is exactly the same. Anyone know which should be the right one for my T43. Also other than the +$20 any difference between these two parts ?
39T0022 HERMES BLUETOOTH AND MODEM WIRELESS COMBO CARD FRU $37.50
39T0024 HERMES BLUETOOTH AND MODEM WIRELESS COMBO CARD FRU $57.50
thanks;
Redrock
hoodaman
#80 Post by hoodaman » Fri Sep 09, 2005 2:26 pm
i have a 2374-3vu and I wanted to find out if i had bluetooth antenna so i can find out how to add bluetooth..
Instead of creating a new thread, i was hoping someone can point me to where i can find out as I dont feel like opening it up just to check.....thanks...
hoodaman
#81 Post by hoodaman » Sat Sep 10, 2005 1:10 pm
anyone?
smkiat
HELP - Neither 39T0022 nor 39T0024 are available from Lenovo
#82 Post by smkiat » Mon Sep 12, 2005 2:09 pm
I just found this forum after acquiring a T43 about 4 months ago. At the time I could not find a configuration with the Bluetooth and a 7200 RPM Hard Drive. Figuring upgrading the hard drive is a no-brainer for me I bit the bullet and ordered one with what I was after but without Bluetooth and with the plan to upgrade the Hard Drive.
I found this thread and was delighted to see there is a way to add the Bluetooth. I checked and found the antenna is in place in my unit (2687D4U). I managed to finally find the proper Lenovo/IBM site to order parts. When I tried to order the Clear Plate (26R8409) and CDC (39T0022). The order site listed the Clear Plate as Available under status but the status for the CDC was Call. I also tried the 39T0024 which can be substituted according to tech support but its status is Call as well. I called this morning and was told they have neither one in stock and no ETA for receiving additional 39T0022s or 39T0024s.
Some third party sites I Googled up are offering the 39T0022 for $157.00 which seems rapacious considering the $37.50 price on the Lenovo/IBM site.
So the question is, does anyone here know of a supplier that offers more reasonable pricing for Thinkpad parts than what I've seen so far. I know a third party will be more than $37.50 but $157.00 is over the top.
T43 2687D4U
arion
#83 Post by arion » Wed Sep 21, 2005 4:40 pm
Does the T41 2373-7JM have an antenna ?
There are 2 or 3 Modem + Bluetooth combo cards. What is the one to get ?
Michael1980
#84 Post by Michael1980 » Fri Sep 23, 2005 10:31 am
Hi, does the 2379-R1U have a bt antenae?
Sorry to ask this, but is there somewhere on the web that lists the models with BT anntenaes already installed?
Rob
#85 Post by Rob » Mon Oct 31, 2005 4:54 pm
I just ordered the bluetooth card.
39T0026 HERMES BLUETOOTH AND MODEM WIRELESS COMBO $46.00
26R8409 CLEAR PLATE KIT FRU $7.06
The 39T0026 is the replacement part for 39T0022, and tech support verified it was compatible with my T43. Just so you know, there is a flat shipping charge of $13.50 so you might as well get both parts now. They're both in stock.
With shipping and tax the total for me was $69.89. Definately a lot more than the $15 I paid for a USB Bluetooth key, but hopefully worth it.
Rob
ulrich.von.lich
#86 Post by ulrich.von.lich » Fri Nov 18, 2005 3:34 pm
Now 39T0026 is $50.00 and 39T0022 is still $37.50, but neither of them is in stock.. Too bad
Do they have the same quality? I'll probably not ask for a replacement.
Btw, what's the Clear Plate Kit?
Does it come with 2 screws?
I still don't know if my 2686-M5U has a bluetooth antenna, it came out pretty late.. How can I make sure of it?
bill bolton
#87 Post by bill bolton » Fri Nov 18, 2005 5:02 pm
Wireless mouse, without the need for a USB separate dongle!
Bill
Shay
#88 Post by Shay » Sun Dec 04, 2005 2:49 pm
Does anyone know if 2668B1U has the bluetooth antenna? I do not think it does, but I thought I would check.
TIA,
Shay
dtakias
#89 Post by dtakias » Sun Dec 04, 2005 2:58 pm
mine does have it.most t43 do.
check under the modem card, its so easy.
there should be a white cable
Shay
#90 Post by Shay » Sun Dec 04, 2005 3:00 pm
Thanks dtakias. I just ordered so I will check when I get it. The funny thing is when I ordered there were not any options to add it in the build.
