Dead T61 w/Nvidia 140M? Here's an option. *PICS*
Mindfulness Quebec
Re: Dead T61 w/Nvidia 140M? Here's an option. *PICS*
Cards that have been tested to work with the setup (from this thread http://forum.thinkpads.com/viewtopic.ph ... &start=210):
- Zotac Nvidia Geforce GT 520
- Radeon HD 5450
- Sapphire Radeon HD 6570 -> http://www.youtube.com/watch?v=XCco69x20Jo and http://www.youtube.com/watch?v=aXzCGBQ0dKY
- Sapphire hd 5570
- Sapphire ATI HD4550 Silent, 512 MB (DVI + HDMI)
- Sapphire RADEON HD 5450 - PCI Express 2.0 x16 low profile, 512 MB DDR3 (DVI + HDMI)
- Asus Radeon EAH6450 SILENT/DI, 1GB DDR3 (DVI + HDMI)
PM me if you have others that work
I have a few older 61's pre-08/08 with NVS140M chips that haven't failed yet (knock on wood). I also have a couple of the Radeon cards and 2503 docking stations. It's a reasonable fix that you propose, but I can't bear the fan noise of that dock with with a Radeon card in it. In fact, with some ThinkPads the fan runs all the time even without the Radeon.
- Radeon HD 5450
- Sapphire hd 5570
crashnburn
So this bypasses the internal card for the external?
Mindfulness Quebec
Yep.crashnburn wrote:So this bypasses the internal card for the external?
jcvjcvjcvjcv
You can just as well mod the dock to either remove the fan or replace it.
W520
T61
T61
Mindfulness Quebec
I would like to know of a replacement fan for the 2503 that is silent and yet prevents the docking station from cooking.jcvjcvjcvjcv wrote:You can just as well mod the dock to either remove the fan or replace it.
crashnburn
Was looking through cheapest existing cards - GT 720 based. 36$
http://www.newegg.com/Product/Product.a ... -_-Product
Should this work?
Should this work?
cadillacmike68
The only problem with this card is that it is made by the SAME cabrons who caused all the problems in the first place. Why give them even 1 penny after what they caused?????crashnburn wrote:Was looking through cheapest existing cards - GT 720 based. 36$
Should this work?
What's the deal with Raedons being branded AMD and Asus? AMD is the one who acquired ATI. Is Asus just re-branding the AMD cards for their systems, sort of like the way IBM branded the Adaptec SCSI controllers back in the late 90s? Are the Asus and AMD cards of the same model identical except for the branding?
760LD 9547 FUBARd
T500 2
T500 2
Most of the differences boil down to:What's the deal with Raedons being branded AMD and Asus? AMD is the one who acquired ATI. Is Asus just re-branding the AMD cards for their systems, sort of like the way IBM branded the Adaptec SCSI controllers back in the late 90s?
1. different cooling system, using axial fans instead of a single blower-type fan in the AMD reference design.
example: Asus R9 285 vs AMD reference R9 285
Blower fans are powerful but quite noisy. Replacing them with axial fans results if a quieter system, which many owners prefer.
2. Slightly faster base and boost clock speeds compared to the reference design.
RIP: 760XD 9546-U9E
RIP: 760XD 9546-U9E
I cut the fan cord a few years ago on both the PSU and graphic cards fan enclosure. Not had any problems with heat but then again I do run a low profile card of just 35watts. (Gt 610 for high resolution monitor only really as not much of a gamer.)
It's amazing how silent my whole setup is.
T61 and streaming video (NVIDIA Quadro NVS 140M)
by Jwolfs » Sat Feb 04, 2017 5:02 am » in ThinkPad T6x Series - 13 Replies
- 2216 Views
Last post by SaskFellow
Sun Mar 26, 2017 6:25 pm
X220 partially dead yellow USB port, dead SD card
by Fusion » Sun Apr 30, 2017 6:44 pm » in ThinkPad X200/201/220 and X300/301 Series - 5 Replies
- 630 Views
Tue May 02, 2017 11:50 pm
(Toronto) FS: T61 15.4" with nVidia nvs140m gpu barebone unit $50
by lincolnor » Fri Jan 06, 2017 8:46 pm » in Marketplace - Forum Members only - 3 Replies
- 666 Views
Last post by lincolnor
Wed Mar 22, 2017 10:03 pm
- 1002 Views
Last post by TuuS
Sat Jan 28, 2017 5:42 am
