Win XP miniPCI combo card compatibility
Does anyone have Win XP running on an A21M with a Lan/Modem PCI card. If so, what kind and where did you get drivers. In a previous post, I cannot get the INTEL Pro card that was working with Win 98 to work with XP nor the the drivers available from IBM. I have got PCMCIA slot combo cards to work, but would prefer not to tie up slots.
GFauss
a31pguy
- Moderator1
Intels website will have the drivers
I think if you go over to the website for netstumbler - the will point you at the site at intel for the drivers. There are a couple of versions - you may want to try the older versions.
No luck on older drivers
I have checked INTEL (Xircom) for drivers. Neither Win 98 or Win 2000 drivers will work. Does anyone know of another miniPCI combo that will work with A21? I think there is a 3com that was also shipped by IBM. Are there others that might work with Win XP?
GFauss
Identify Wifi Card Win 7 64 bit X230 & missing bits device manager
by blink » Tue Feb 28, 2017 8:56 pm » in ThinkPad X230 and later Series - 3 Replies
- 481 Views
Last post by w0qj
Tue Mar 07, 2017 3:55 am
T430s mSATA compatibility
by Chronoculars » Fri Jan 06, 2017 8:41 pm » in ThinkPad T430/T530 and later Series - 10 Replies
- 1185 Views
Last post by thinkofit
Fri Feb 03, 2017 3:24 am
- 5 Replies
- 641 Views
Last post by intelfx
Fri Jan 13, 2017 9:28 pm
Thinkpad Helix Pro Keyboard compatibility (Gen1 vs Gen2)
by Boxxer » Fri Jan 13, 2017 12:03 pm » in ThinkPad X1/X1C - 6 Replies
- 3881 Views
Last post by mcintyrerj
Sun Apr 30, 2017 5:28 pm
