AHCI and SSD
cadillacmike68
Re: AHCI and SSD
Thanks for the info dr_st.
True on the preferences. Reviving from a hibernation would hang my machine while it tries to re-establish a non-activated internet connection.
On the pagefile being on an SSD, wouldn't all those writes shorten the life of the SSD? I know that the newer ones are supposed to be much more reliable but there is still a finite number of writes a particular SSD cell can tolerate.
I'm still a ways away from getting an SSD, need to get a win 7 license (not going to bother with an SSD and XP), and figure out a way to port the applications - if possible, because there are so many to bring over. That's probably not possible, so the rule of inertia will likely dig in and cause me to put this off even further.
760LD 9547 FUBARd
T500 2
T500 2
Re: AHCI and SSD
. Perhaps. So? There are a finite number of actions any device can take. Should we read in the dark because there is a finite number of hours the lightbulb can work? There is also a finite number of breaths we can take. Should we stop breathing?On the pagefile being on an SSD, wouldn't all those writes shorten the life of the SSD? I know that the newer ones are supposed to be much more reliable but there is still a finite number of writes a particular SSD cell can tolerate.
As was said earlier in this thread, by myself and Thinkrob at least, with modern SSDs there is no need to be too concerned with writes. I haven't seen a single survey or practical research that showed that normal read/write patterns shorten the life of the SSD below what is still about twice the life expectancy of the average computer. The average hard drive will probably die way before that.
Re: AHCI and SSD
As far as I've read, cases of SSD dying unrelated to flash endurance are not unheard of, but cases of SSD dying related to flash endurance haven't crossed my mind, yet.
It seems that sometimes people forget that electronics are/can still (be) consumables, they just usually last (much) longer than their mechanical counterparts.
Cheers.
Cheers.
Re: AHCI and SSD
I love ssds, use them to the max, but remember have a good backup/recovery plan. When they quit, they usually give no warning.
Scott
Scott
Re: AHCI and SSD
"Prefetch", at least in Windows terminology, is probably not a useful feature with an SSD. It's exactly what it says on the tin: pre-fetching data that the OS expects to use so as to avoid waiting on slow IO (particularly slow random IO.) SSDs don't suffer from slow seek times and are generally fast enough that I wouldn't bother.
Hibernation? Keep it if you use it, drop it if you don't. Personally I don't use it since it's a serious security risk for those of us that use encrypted filesystems...
Current laptop: X1 Carbon 3
Current workstation: noneRe: AHCI and SSD
Folks, there is a thread on another forum that seems to read like garbage collection takes place using Xp and a Crucial drive, any comments? see link below
http://forums.anandtech.com/showthread.php?t=2229683
Re: AHCI and SSD
Hmmm, Windows or Linux? I use hibernation on an SSD in Linux with a LUKS encrypted LVM setup. This way everything apart of the small boot partition hosting the kernel is encrypted, included the swap volume used for hibernation.ThinkRob wrote:Hibernation? Keep it if you use it, drop it if you don't. Personally I don't use it since it's a serious security risk for those of us that use encrypted filesystems...
Re: AHCI and SSD
I haven't seen a proof of that statement in the linked thread...burns334 wrote:Folks, there is a thread on another forum that seems to read like garbage collection takes place using Xp and a Crucial drive, any comments? see link below
Re: AHCI and SSD
afaik both BitLocker (asks for my encryption key when I resume from hibernation) and (afaik) TrueCrypt also encrypt the hibernation file, so I have no idea where this security issues is supposed to pop up.rumbero wrote:Hmmm, Windows or Linux? I use hibernation on an SSD in Linux with a LUKS encrypted LVM setup. This way everything apart of the small boot partition hosting the kernel is encrypted, included the swap volume used for hibernation.
S3 Standby, that is a security issue indeed for full-disk encryption. Hibernation? would be new to me.
Re: AHCI and SSD
I like the work "proof", exactly how can one see if it is collecting garbage or not?
Re: AHCI and SSD
Elementary, my dear Watson...burns334 wrote:I like the work "proof", exactly how can one see if it is collecting garbage or not?
How TRIM works is rather well known and I'm not going to explain it here.
We ALL know that there's no TRIM support in XP or Vista.
Therefore, one would need a program that can be run manually in order to perform "garbage collection".
I'm well aware of such utilities for Intel and Samsung SSDs, but not for Crucial ones although C300 and M4 take the second and third place on my "Top Five" SSD list.
The fact that someone states "yes, that's what the drive does when it's idle" doesn't hold much water, not with me anyway.
In the world where marketing is (almost) everything, I'm dead certain that Crucial themselves would be loudly advertising such a capability if it were there in the first place...
Re: AHCI and SSD
It may not, but it is imperically-observable. Anandtech's benchmarks do a good job of demonstrating this.ajkula66 wrote: The fact that someone states "yes, that's what the drive does when it's idle" doesn't hold much water, not with me anyway.
Current workstation: none-
cadillacmike68
Re: AHCI and SSD
Well, My T30 is 10 yrs old, so an SSD should last 20 years?dr_st wrote:Perhaps. So? There are a finite number of actions any device can take. Should we read in the dark because there is a finite number of hours the lightbulb can work? There is also a finite number of breaths we can take. Should we stop breathing?
760LD 9547 FUBARd
T500 2
T500 2
Re: AHCI and SSD
Via Slashdot...
"SSD Write Endurance Considered... Sufficient"
http://ef.gy/statistics:ssd-write-endurance
Cheers.
Cheers.
Low Intel X25-M G2 SSD read speed in X60s with AHCI
by dandreye » Wed Feb 08, 2017 5:59 am » in Thinkpad X6x Series incl. X6x Tablet - 19 Replies
- 1944 Views
Last post by dandreye
Mon Mar 06, 2017 7:35 pm
- 4 Replies
- 1389 Views
Mon Mar 06, 2017 12:32 pm
- 1357 Views
Last post by w0qj
Wed Jan 18, 2017 11:11 am
WTB: Thinkpad with good processor , ssd and 32+GB RAM
by Farro » Thu Jan 19, 2017 9:11 am » in Marketplace - Forum Members only - 4 Replies
- 440 Views
Last post by Farro
Mon Jan 23, 2017 11:55 am
