anyone used a 1.8''/mSATA adapter in a T400s/T410s?
I'm wondering if anyone has experience with fitting one of the generic adapters you find on eBay to a T400s and T410s.
The idea has been floated already on this forum but I've not seen any report of a sucessful replacement of a T400s/T410s system drive with a mSATA SSD + cheap adapter.
Re: anyone used a 1.8''/mSATA adapter in a T400s/T410s?
I am interested to hear as well.
I bought one of the cheap generic adapters from ebay shipped from China several months ago and have it sitting on the shelf. I never got around to buying the mSATA drive to install in there. My decision was set on the Muskin Direct Atlas Deluxe 240GB or 120GB.
I got this screen issue on my T410s, and have been hesitant to put any more money into it: http://support.lenovo.com/en_US/detail. ... MIGR-76367
jayton4
Current models/upgrades:
T410 2518X01- 8GB, Corsair Force GT 120GB
T410s 2901A3U- 8GB, Intel 6300 WiFi, Crucial m4 mSATA 256GB SSD w/ microSATA adapter
T420s 4174PPU- 16GB, Intel 520-series 7mm 180GB SSD, Crucial M550 512GB mSATA SSD, Intel 6300 WiFi
and a few classics in storage
Have you simply tried to fit the adapter in the laptop? Is the fit secure?
There are more expensive adapters with extra plastic that gives it a shape more similar to that of a 1.8'' drive than the cheap eBay adapters. If your cheapo doesn't fit well, I might try one of the more expensive adapters.
It fits well. I slid it in and then tried to see if it would come lose by shaking and jarring the computer. It stayed put just fine. There is a large gap underneath the adapter where I would probably put a folded up paper towel to hold it in a little firmer for the long term.
I just changed out the screen in my T410s, so I may end up getting the SSD anyway.
jayton4
Yes, I have successfully replaced the stock 1.8" HDD in my T410s with a Crucial M4 mSATA SSD, using an adapter by Micro SATA Cables (www.microsatacables.com).
I used a cut-out piece of foam envelope (for the adapter) to pad the drive/adapter combo in the main bay.
strikeback03
Did you use the adapter with the hard drive caddy or just loose in the bay? I've been looking for a caddy for the 1.8 inch bay and not finding one yet, maybe this is a way around that.
For the T400s and T410s, no caddy exists. The drive itself slides in/out on these. As the above posts mention, it is probably a good idea to find some non-conductive material to fill the gap with these mSATA to microSATA adapters.
jayton4
- 0 Replies
- 241 Views
Last post by BobA
Sun Mar 26, 2017 10:10 pm
Used msata SSDs?
by Digitalhorizons » Mon Feb 13, 2017 9:20 am » in ThinkPad X200/201/220 and X300/301 Series - 3 Replies
- 840 Views
Last post by ajkula66
Mon Feb 13, 2017 7:52 pm
Story about a x40 msata ssd, pata chinese adapter and southbridge...
by silca80 » Fri Mar 31, 2017 3:06 pm » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 6 Replies
- 608 Views
Last post by silca80
Sat Jun 24, 2017 7:04 pm
FS: misc parts.... lightly used classic keyboard | 4GB DDR3 RAM | lightly used T500 palmrest, bezel
by tpdude4 » Sat Dec 31, 2016 9:06 am » in Marketplace - Forum Members only - 6 Replies
- 690 Views
Last post by tpdude4
Sun Jan 15, 2017 6:45 am
Users browsing this forum: sfiber and 10 guests
