Johan, the panels in that ali express listing have brackets on the top and bottom which none of the ones I was selling had any such brackets and if they cannot be removed they would need to be cut off.
I can also confirm that all the panels in this forum post have been sold years ago. In order to get one today I'd expect to pay $200-300 or more, or you can try your luck with the ones listed on ali express, but I doubt they accept returns after you cut off brackets.
Hydis HV150UX2-100 LED displays 15" UXGA (new)
fatpolomanjr
Re: Hydis HV150UX2-100 LED displays 15" UXGA (new)
You can remove the brackets; they are just like the standard brackets Lenovo used in the T6x generation Thinkpads, which are removable with a phillips screwdriver.
The problem with these aliexpress displays is that, from what I can tell, none of them are ever actually New. Despite what the packaging might lead you to believe. I purchased a Used/Like New one from a seller on amazon and it had dust under the display (works fine otherwise). I later purchased a "New" one from aliexpress and it developed a nasty rounded/square halo of backlight all around it after a few days! I'm holding onto the one with the dust for a rainy day in the case my current display ever goes bad, since I was eventually able to live with it.
T60/61 Frankenpad | 15" UXGA LED | T9300 | Intel X3100 | 8GB RAM | 256GB SSD | Manjaro i3 / Windows 7
X62 | 12.1" SXGA+ Xiphmont LED | i7-5500U | 8GB RAM | 256GB SSD | Xubuntu / Windows 10
Thinkpad 10 Tablet | Atom Baytrail | 128GB eMMC | 4GB RAM | Windows 10
Realistically, $350 or thereabouts is the price for an unused LCD of this kind nowadays unless one gets very lucky.
Having said that, the sheer possibility of breathing new life into any machine with 4:3 UXGA format is simply priceless, at least for silly old me.
This post brought to you courtesy of my R61FL with the aforementioned Hydis LED screen...
LED Screens and The T400: Can an LED Screen Swap to Non-LED Model
by KingBubba » Sun Apr 30, 2017 1:15 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 5 Replies
- 591 Views
Last post by KingBubba
Mon May 01, 2017 11:23 am
T42 Boe-Hydis Panel Compatibility with T60
by Thinkpad4by3 » Mon Mar 13, 2017 9:34 pm » in ThinkPad T6x Series - 3 Replies
- 1693 Views
Last post by ajkula66
Tue Mar 14, 2017 8:53 am
1440 x 900 Or 1600 x 900 Displays Compatible For X230 (And Future Plans With X230)
by TheMagicT410 » Sat Feb 18, 2017 10:02 pm » in ThinkPad X230 and later Series - 4 Replies
- 1036 Views
Last post by TheMagicT410
Sun Feb 19, 2017 8:45 am
Windows 10 Creators breaks screen dimming and external displays
by charlieo » Sun Apr 23, 2017 2:00 pm » in ThinkPad X1/X1C - 4 Replies
- 374 Views
Last post by TankPad
Sun Apr 23, 2017 9:07 pm
